Question about Epson Aculaser C1100 Printer
Epson C1100 - Vertical faint stripes on colour photos
On colour photos printed on Epson C1100 there are vertical white stripes.
How can I fix this, (I have replaced the toners)?
Bending the top convex with a hot air gun solved the problem for me!!
Posted on Jan 11, 2012
  • 4 Answers
See if this solution fixes the problem.
Also clean the print head using instructions in the manual
http://www.fixya.com/support/t241840-smudges_color_printing_black_ok
Posted on Mar 06, 2008
MY PROBLEM IS MY 230 PRINTER VERTICAL PRINT IS NOT
I have problem while printing colour photos and I would like to know how to print back to back i.e. even and odd pages
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
EPSON C1100
Your problem isn't too hard to fix. If you have a vertical line down the page chances are that your heat unit roller is either scratched and so can't fuse the image in that section or has something on it. This is a bit tricky to fix yourself as your supposed to have a tech guy take the heat fuser unit out. You can do it yourself but have to be confident that you can put it back together. Take care it's usually very hot.
This printer often reports a jam in the back paper loaders if a page doesn't grab properly (or you quickly remove a sheet just before it grabs to print). Simply open the back door and shut again. If this doesn't solve it chances are there is something stuck in there. Hope this helps
May 22, 2009 | Epson Aculaser C1100 Printer
Solution for "I have a Epson Aculaser c1100 and four coloured dots have appeared when printing. These dots are approximately 5cms from the left side of the page and print in a small vertical group. Each...
The four coloured dots are what is known in the trade as "Traffic Lights". They happen when the photocuductor (PCU) drum gets scratched. If you do a black only print you will only get a black dot, if you do a print with some colour in it you will get all four dots repeated at 150.41mm (PCU drum circumference) intervals. The best answer would be to replace the PCU but it is expensive. The alternative is to take out the PCU, find the scratch and try to polish it out with a very soft cloth. This will only work on the lightest of scratches. Be very careful not to scratch the drum further and avoid shining any bright light on it as it will damage the photo-sensitive surface (normal ambient light is OK).
Apr 11, 2009 | Epson Aculaser C1100 Printer
White vertical line in image printing
how can we take all fax sent and received print from hp 3050 printer.
Apr 01, 2009 | Epson Aculaser C1100 Printer
Epson aculaser c900
When printing, as thepaper is being transported up the printer, try pressing the right door panel of the printer firmly with your hand. If the colours are much improved then the printer requires a new Transfer roller.
1. Open the Right Door.
2. Remove the Transfer Roller while opening the shaft holder (white color) levers found at the left and right shaft ends of the Transfer Roller to unlock it. Lift out the roller.
Jan 21, 2009 | Epson Aculaser C1100 Printer
Colour smudges
try cleaning the print head and also see this post on the photoconductor
Jan 23, 2008 | Epson Aculaser C1100 Printer
Epson AcuLaser C1100 - rainbow stripe
could be the photoconductor. see this post below, also try cleaning the print head
Jan 18, 2008 | Epson Aculaser C1100 Printer
Print quality Epson C1100
It sounds as though a cartridge is faulty. To determine which one, the easiest way is to run a page of text/block of colour through in yellow then cyan then magenta. which ever page comes out with the streaks on it will tell you which cartyridge to ditch and replace. Hope this helps Cops Pete@wedotoners.com
Oct 10, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
881 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
