Question about Bissell 9200 Upright Vacuum
Bissell 9200pro heat2x
Doesn't suck up the water is it the pump
  • d0llface Jul 31, 2008
    the water shoots out but not sucked back in. how do i fix it?
  • Anonymous Apr 26, 2009
    I have a Bissell 9200 - E carpet cleaner and it has no suction for the floor cleaner. The hose has more of the suction.
    what do i do? HELP!!! my carpet is soaking wet because there is no suction.
    Problem Solver:
  • 7 Answers
Might be the tank isnt seated on the oval gasket/oval gasket might be worn out or turned upside down/tank might be warped cause of putting too hot of water in it
Posted on Aug 22, 2008
    President:
  • 1,673 Answers
Wouldn't be the pump, the pump pushes the water out when you are spraying. If a suction problem check for clogged filters, is the tank sitting down tight?
Posted on Mar 04, 2008
I have a bissell pro heat2x turbo. my problem is that the sprayer underneath is not working, also it sounds as if there is air coming from somewhere.
Sounds like there is a leak or crack somewhere in your tank.
Check the tank and tubes for damage or clogs. You may have to replace your tank.
Proheat 2X Shampooer Shampooer Parts
800-775-6586
GoodVac com
Feb 22, 2015 | Bissell Vacuums
My bissell proheat pet will not suck up water
Check the filters. User's Guide has locations. one under water tank cap one under Flow Indicator. They are small but need to be cleaned after each use.
Jul 18, 2014 | Bissell Pro Heat Orginal belts
My bissell will not suck the water
Check User's Guide for filters. One under the water tank cap (looks like a small screen) and one under Flow Indicator. Bissell Consumer Care 1-800-237-7691
Jul 18, 2014 | Bissell Proheat 2X Select Pet Upright Deep...
My bissell proheat 2x mutisurface turbo model T doesn't suck up the dirty water
take water container off and when you put it back on make sure it seals
May 20, 2014 | Vacuums
Www bissell com
Replace belts as they run pump. If water at tool but not at floor the heater or water jets clogged. If no water at all the pump may need replaced
Oct 02, 2013 | Vacuums
My Bissell Proheat carpet cleaner is not sucking up the water. How do I check the pump belt. The motor sounds fine. Thank you
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 05, 2010 | Vacuums
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The Bissell won't spray any carpet cleaner but it is still sucking up water.
If it doesn't dispense water then that means that you need to replace the pump belt. Here is a link to the belt you nee and the manual:
Bissell ProHeat Belt and Manual
Dec 27, 2009 | Bissell 1699 ProHeat Clear View Upright...
Will not distribute water
pump...or if it is a heating system.....disassemble the heating element and u will see lots of build up of a sodium/chlorine clusters inside of it, clean it out and if that does not work,,,,pump
Jan 20, 2008 | Bissell 7901-7 Proheat Upright Vacuum
Bissell 9200 Upright Vacuum Logo
289 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
