Resetting the fuser oil message
I have a Savin C2410 copier, on the screen it reads fuser oil low, I bought fuser oil from precision roller but I cant figure out how to reset it, moneys tight or I would call a service company to come out.
  • 87 Answers
Well, all you need to do is fill the tank on the back right of the machine. The oil pump has to pump it up to the sensor in the fuser. It will eventually go out, or you will get an SC570 code.
Posted on Mar 04, 2008
How do I reset fuser code on savin 2513 with a sc544. I have checked the fuser lamp thermal fuses etc. From the power source in cable unplugged. The thermistor reads about 390 k ohms at room temp. It had a...
When reading the thermistor, grasp the sensing part between thumb and forefinger, if reading drops quickly the thermistor is probably goid, if so , unfortunately you may need a power supply board
Feb 12, 2015 | Savin Office Equipment & Supplies
Error code sc571
You need to fill the oil tank with "silicon oil" i'm I'm not sure where your're from, but where I am its virtually impossible to get it apart from a dealer or a company such as Katun.
Once you have replenished the oil the error code will have to be reset, I would only let an experienced tech do it as you have to enter the service mode on the machine, and pressing the wrong buttons can cause untold problems.
Sep 20, 2012 | Savin C2410 Cyan Toner Cartridge...
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Savin copier c2410 error code 421?
http://www.restoreguard.com/p/error-421.html?keyword=Error%20code%20421&gclid=CNTmo4vZ26UCFYtspAod1CIj0w
very common fault with win 7 click the above link and it will install the corrupt / missing program files
Dec 08, 2010 | Savin Office Equipment & Supplies
Savin printer showing E 54.What does this mean?
If it's actually a Savin 2575, then you're missing a digit in the error message; However, any Savin machine that gas an error of '54x' relates to a fuser problem, and it can only be reset in service mode after the problem is fixed.
Jul 14, 2009 | Savin 2575 Black and White Copier
Savin 9935DPE document feeder maintenance
GO ONLINE TO SAVIN: TYPE THE FOLLOWING INFORMATION:
WWW.SAVIN.COM/SERVICE_MANAUL
/TECH_SUPPORT
/SERIVES
/HELP?
CALL SAVIN ASK TECHICAL SUPPORT, ASK FOR A TECHICAIN THAT REPAIRS OR FIXS THAT TYPE OF EQUIPMENT AND EXPLAIN THE PROBLEM AND SEE IF HE HAS ANY IDEAS YOU CAN TRY BEFORE YOU GO OUT AND SPEND ANY TYPE OF MONEY ON THAT PART.
ROD
May 12, 2009 | Office Equipment & Supplies
Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Mar 07, 2008 | Computers & Internet
589 people viewed this question
k24674
jasbo
jasbo
