Question about Frigidaire PLHS267ZA Side by Side Refrigerator
Refrigidare model # plhs267za
Everything in the refrigirator is freezing. The freezer is working fine but the refrigirator freezes everything solid. I have replace the filter 3 times thinking that may be the problem. The motor went out about a year ago it was replace and all was fine but about 5 months ago it did this once then all was fine now it is a daily problem. help please thanks Wayne
    President:
  • Frigidaire Master
  • 2,651 Answers
Sounds like the air damper control for refrig is freezing in the open positon. not a really consumer freindly repair,(dropping side control panel checking damper door for ice build up, removing ice and applying a silicone lubricant(vasiline) to prevent further freezing of air damper motor. sounds easy enoug but that panel is real tricky to drop and mount back in.
Posted on Mar 04, 2008
solid blue is the coldest setting
Oct 14, 2015 | Refrigerators
Ice maker not working
Has it ever worked? Is the freezer freezing everything solid?
Apr 06, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing ice cream and milk
Icecream is a tough call. Some brands have to many artaficial ingredients and that doesnt get solid. What temps are you getting in the freezer? Is everything else frozen solid?
Jul 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
PLHS267ZA
The guide that funnels the water into the ice maker needs to be replaced. The cause of your problem is that water is leaking into the back, freezing there, and blocking the air flow. Mine sounded like an idling semi truck with engine problems.
Jan 06, 2009 | Frigidaire PLHS267ZA Side by Side...
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
Frigidaire Model # FRT15G5AWO Top Freezer Refrigerator
frigidaire makes a garage kit to operate refrigirators at lower temps. the kit is about 18.00 dollars, it is avaliable from electrolux,1800-599-7569
Feb 16, 2007 | Frigidaire FRT15G4B Top Freezer...
Frigidaire PLHS267ZA Side by Side Refrigerator Logo
322 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
