Machine will fill with water and spin, but not wash.
Machine is working intermittently. Last two loads will fill, but not agitate or wash, but will spin if manually directed to. But, won't wash if you manually direct it to. Got all the numbers off the machine, but none seem to match with yours. It's a Kenmore Limited Edition, Model 110.23912100, part number 39529686. Hope you can help.
  • twomos Mar 06, 2008
    Controls are bad doesn't help much. Can you explain how to fix the controls?
  • Ron Coons
    Ron Coons May 11, 2010
    when in agitaion mode, does it do anythig???hear anything?? just stalls in one position. its more common an issue if this machine fills and agitates, but doesnt spin
  • 156 Answers
Controls are bad
Posted on Mar 05, 2008
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
My front load washing machine agitate but won't spin
If your machine is rather old or used quite frequently, you should check out the motor brushes. Go to youtube for details on washing machines brushes.
Mar 06, 2015 | Washing Machines
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Agitator does not work
    Your motor runs in forward and reverse...the spin is one way and the agitate is the other... that direction has failed. Replace the motor...
    If you are having a problem with your top load washer then check out this tip...
    Washing Machine2_bing.gif does not Pump or Spin
    http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
    If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
    Front Load Washing Machine2_bing.gif not draining and or not spinning
    http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
    heatman101
    Jul 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
    Whirpool washer wont work
    The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
    Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
    Machine doesnot agitate or drain once filled with water
    it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
    Apr 24, 2009 | Washing Machines
    Will fill and drain, not agitate or spin though
    I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
    Jan 22, 2009 | Roper Washing Machines
    Frigidaire front load washing machine won't stop filling
    it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
    Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
    Washer problems
    if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
    alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
    Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
    Washing Machines Logo
    73 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
