Color board settings in front drop pannel have been changed how do i get them back to orginal setting
  • renegotiear Mar 06, 2008
    thank you for your quick responce the make and model is as 1993
    zenith PV5267RK color board settings in front drop pannel have been changed how do i get them back to orginal setting? my email is renegotiear@hotmail.com
  • renegotiear Mar 10, 2008
  • 8,617 Answers
What is the make and model number of your set?
Posted on Mar 05, 2008
Do I need to replace the LED pannel of my tv if there is backlight?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 07, 2017 | Samsung Televison & Video
Using control pannel does not change my screen resolution help
did you click apply after changing any settings ?
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
Oct 06, 2012 | Dell Inspiron 1100, 1150, 5150 & 5160...
How do i change desktop back drop
windows 7
Open Personalization by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
Jul 28, 2012 | ASUS Accessory 90-XB2UOKSL000B0 Epad...
For the ps3 if i change to HD settings, how could i change back?
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps32_bing.gif will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all
May 08, 2010 | Sony Playstation 3 (PS3) Console
Hi, my mother board is HP d530 SFF ...i installed the correct audio drivers and its shows no problem in software ...but still i m not getting sound from my back pannel.can any one help me how to connect...
There is "Front Panel Audio" connector on mb. If you don't use orginal connector from orginal case you must short pins on mb.
2 o o o x o 10
1 o o o o o 9
If you short pins 5&6 and 9&10 you should have sound at rear audio panel of mb.
I have run into this on a different compaq model in a different case. It maywork for you but must find small jumpers if they are not supplied. No guarantee but worked on my compaq d530
Aug 05, 2009 | HP D530 PC Desktop
Need to adjust web cam settings on asus computa
my webcam is upside down and i cant change it back.. how could i do this?
Jun 17, 2009 | ASUS A8Jm Notebook
When i scan a letter 2 page is scanned:letter and blank page
You may be set for front & back (duplex) scanning. Change the setting for front only or simplex. This could be done with check/uncheck boxes, a drop-down menu, or a keyboard shortcut. I believe the standard Kodak settings are via check boxes.
This model is also capable of putting out color & bitonal (black&white) images simultaniously. If that's the case the pages should be separate image files. Uncheck either color or bitonal depending on which you want.
Apr 09, 2009 | Kodak i40 Path-Through Scanner
I have msi945 board
Try checking the front panel in bios. It may be disabled there which would mean the front panel jacks would not work. Hope this helps.
Dec 19, 2008 | Intel Motherboard
The dark colos have a lil' green on them...why?
How old is this set? Sounds like a CRT issue, might be able to adjust the G2 control (SCREEN), you will have to pull the bottom pannel off the front and there should be another little 1/4" thick board that comes off with a few screws and then a 6 knob control, turn your color all the way off in the menu and adjust your screen controlls up till you get some overcolor with lines in it and then back down just before the lines (MAKE SURE YOU DEFAULT ALL YOUR USER MENUS) check that you have a black and white picture after adjusting all 3 screen controls like before with the menu color off. If you have a bad CRT it will go again, the CRT may no longer be available, if the set is not too old i.e. 5-8 years old it may be a defect with multiple CRTs.
May 22, 2007 | Sony KP-53HS30 53" Rear Projection...
Home theater
The front pannel,on and off channels and vol. switches are going bad,if you dont use the front pannel, unplug the set and remove the back cover,just below the top screws you can look under and see the top of the picture tubes,in front of the middle tube is a little board about two inches wide and four inches long,unplug the right plug it has one black and five or so white wires,this is the top cable,then just use your remote.
Nov 20, 2006 | RCA P60920BL 60" Rear Projection...
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
