Question about Zebra Stripe S600 Thermal Label Printer
Labels printing in reverse order
I have 2 identical label printers. They have been working fine until a couple of days ago. There are 3 lables that print for pharmacy..... on one printer, they print in order (ie: label 1, label 2, label 3) and on the other printer, they just started printing (label 3, label 2, label 1). All the data is correct, it's just the order of what is printing. Any suggestions?
  • GeorgiaGirl Mar 06, 2008
    This was not a software problem with the application that we are printing from. I had already eliminated that before posting my issue.... what I had to narrow it down to was the print queue itself or the port on the term server that the label printer was connected to. I deleted the print queue and recreated it and it fixed the problem.
  • Anonymous Mar 20, 2009
    I have the same issues with some Z4M printers. Even the config page comes out reversed...
  • 3 Answers
I work from home and use to do all my own label printing. I would have to admit that I was not really quite the big fan of these printers as my printer was so temperamental and my labels never came out the printer looking professional enough. Becoming fed up of the endless battles with the printer finally decided to look for another solution into getting my labels printed. I found a company called <a rel='nofollow' href="http://www.selfadhesivelabels.com/">Mercian Labels</a> who specialises in <a rel='nofollow' href="http://www.selfadhesivelabels.com/label-printing.html">label printing</a>, they now print all my labels for me at such a slow cost and are so efficient I would never go back to printing my own labels.
Posted on Mar 17, 2008
  • 38 Answers
It's not the printers, has to be the software.
Contact your vendor for support.
Steve
Posted on Mar 05, 2008
How can i print?
Go to the Argox web site does your model printer do labels? check the media spec's. Are using the correct setting in the print driver? Check the printer setting on the machine. web site mite have a work around also might go to web site down load up grade driver to allow ding lables
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 16, 2015 | Argox OS-214 Label Printer
Can Cymo lables be used in the Smart Label Printer 100
If you mean Dymo labels and if the Dymo labels have a black rectangle on the reverse and if the labels aren't to wide, then the labels should work. You may run into problems with the Label printer advancing too far after printing; unfortunately, you will have to manually re-align the label after printing
Feb 13, 2014 | Seiko Smart Label Printer 100 Thermal
I have a BROTHER MFC-8480DN all in one printer which I just purchased. My avery lables do not work right as the first 2 rows are okay and then the text does not fit right on the following labels. I use it...
Lables are slick some time the feed rollers will slide on them. Try to find lables that are course with no shine on them . The rubber that the tires are made of is of poor quality. Just dont have the grip . Hope this helps
Aug 12, 2010 | Brother Office Equipment & Supplies
"PLATEN ROLLER" rotating in reverse order.
i will suggest that maybe a drive belt inside your printer has come off a pulley. remove the power cord, remove cover and take a look inside. you can probably get a diagram from toshibas website. and more troubleshooting information too...good luck
Apr 04, 2017 | Toshiba B-SA4TP Label Printer
Z4M printer suddenly running in reverse
The problem is in the power supply board and must be replaced. What fails is the chip stepper motor driver.
Mar 10, 2009 | Zebra Z4M Printer
Zebra 2844 won't print anything.
Sounds like you may have taken out more than the fuse. In case there is still life the next thing to try is a printer reset
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Jan 26, 2009 | Zebra LP 2844 Thermal Printer
Issue trying to print mulitple labels, red light
The physical label size must be set in the printer driver, both in the "Properties" and the "Default" tabs.
Jan 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
PRINT WILL NOT STAY ALIGNED ON EACH LABEL-RUNS ONTO NEXT LABEL
Check the tension on the Ribbon Take-up Spindle there is a nut on it that sometimes can loosen or tighten its self and will throw off the lables. Its a nut that has a of couple Hex nuts on the corner, screw the nut to about the 3rd thread from the top of the bolt facing you then tighten the hex nuts on the corners of the nut. Then try printing the labels make sure the media guide also is set to the lable size that is installed.
Dec 19, 2008 | Zebra 105SL Thermal Label Printer
Zebra 110XiIIIplus printer
Turn the Printer off and turn it back on. See if it skips a couple of labels. If it does not the printer needs to be calibrated.
Press the Setup/Exit Key and the press the Next Key until you see Media Power UP: IT should say Calibration if it don't then use the arrow keys to get to Calibrate press the Next key again and you will see Head Close select Calibration using the same method mentioned above. After that Press the Setup/Exit Key and Save Changes Permanent. Turn the printer off and on again and the first 2 labels should skip while the printer aligns the media.
Test Print and see if that fixes the problem. Good Luck
Sep 29, 2008 | Zebra 110XiIIIplus Direct Thermal/Thermal...
Labels enlarged
if they are diferent resolutions, ex. you change from 200 dpi to 300 dpi, you need to change something inside the printer like the gears (just reversing the platten roller gear and the the withe gera on the motor) and you are printing on 300 dpi with very small fontes.
Mar 11, 2008 | Zebra Z4Mplus Label Printer
Zebra Stripe S600 Thermal Label Printer Logo
557 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
