Question about Canon GL1 Mini DV Digital Camcorder
Eject tape message
Upon trying to playback a mini dv tape, the lcd blinks with message
Eject tape.
Please advise.
We get the eject message and then it will not eject tape.  Any suggestions
Posted on May 29, 2008
JVC mini Dv GR-D720E has small squares on playback
Indeed it seems that there was a really stubborn bit of dirt on the heads. I had to use the cleaning tape several times to ultimately have a clear picture on record and playback.
thanks again ,but successive cleaning can help for an effective cleaning of the tape path and heads.
Feb 04, 2010 | JVC GR-D73E Mini DV Digital Camcorder
Samgung SC-D353 camcorder 'EJECT' problem
sc-d353 got wet slightly the camera part is working but good tapes display eject sign and in the middle of the screen displays the eject symbol and ...r please help
Jun 02, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Panasonic DV mini camcorder error message
Inside is a sensor that detects moisture. If there is dew inside the unit, the tape will adhere to the head and create all kinds of problems. This sensor is there to to prevent problems. That being said, the repair for this could be as simple as ejecting the tape leaving the unit open and letting it dry out. It could also be a bad sensor. In the case of the sensor, the parts cost would be in the $10-$20 range. Add in the local labor rate ($175 here in Mass) and you have the total repair cost. While this is not the easiest repair because of its size, anyone that works on camcorders will find it straightforward.
Dan
Sep 12, 2008 | Panasonic NV-DS60 Mini DV Digital...
Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system.  Requires a visit to the service shop.
Jan 28, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
Canon Gl2
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 18, 2007 | Canon GL2 Mini DV Digital Camcorder
Playback
That's dirty video head! Try to playback new tape for five minutes, do it for 2 to 3 times, this will serve as your videohead cleaner. eject then reinsert then playback, eject again for at least 3 to five times. most camera has a built in videohead cleaner that activates during eject, initial play and reinsert mode. you can even try to play the whole blank tape! thats 1 to 2 hours of playback! If the problem is still there after doing those things, you need pro fix then.
Sep 13, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
I cant get any video playback via LCD or via TV?
Hello Meerdorf, please buy the cleaning cassete for Mini DV and try to clean the head and tape path. Best regards, Arpad
Dec 22, 2006 | Samsung VP-D20 Mini DV Digital Camcorder
Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Sep 04, 2005 | Canon ZR25MC Mini DV Digital Camcorder
Canon GL1 Mini DV Digital Camcorder Logo
575 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
