Question about Polti Vaporetto 2400 Canister Steam Vacuum
New hose lance and brushes
I want tobuy a new hose lance and brushes for my steam cleaner. could you please tell me where I can purchase these from? Please reply to wilkinssandra@hotmail.com
    Problem Solver:
  • 17 Answers
There is one for sale on ebay.co.uk if this is any help
Posted on Mar 11, 2008
I have a Hoover V Steam Vac model F7412. The tank for the clean water and cleaner fluid leaked out the bottom. I purchased a new tank but something in that area is still leaking. I know it is not the...
My clean solution tank is leaking from the bottom, too. It is not a hose or a valve. The clean solution tank is leaking in-between the clear plastic walls of the solution tank & the grey plastic bottom that are connected, together. I was thinking of caulking it all around the bottom where the clear plastic sides join the grey bottom plastic. I can't get into ordering a new one (spending $) unless Hoover will send me a new one for free. Purchased at Kohl's in Massapequa, NY in June 2008. There's a one year warrantee AND the directions say to EMPTY the solution tank after each use. Which I normally do because the tank runs dry.
Aug 08, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
No steam comming out of my h2o x5 cleaner
see the causes and proceed with common sense. and fix it. God bless you
If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on a steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly
  • Sep 22, 2012 | H2o TR220002 Steam Cleaner
    My Bissell Pro Heat 2X steam cleaner is not releasing the water
    Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
    Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
    I was steam cleaning the stair landing and the steam cleaner slipped off the landing a few inches and the brushes haven't worked since
    Please remove the brush assembly by pulling down from the bottom of the cleaner. There is a drive pin to the brushes, approximately 1/4 inch square and two inches long that connects the brush to the drive mechanism. You may have broken the pin off, and need to replace the brushes.
    Oct 12, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
    Brushes
    Sounds like the belt is broken or at least the brushes are bound up with carpet fibers. Take a look and see which it is.
    Feb 14, 2009 | Bissell 1699 ProHeat Clear View Upright...
    Help with steam cleaner
    DId you push the little button located at the rear of the attachment on the top? It is gray and part of the hose peice. It is what holds it the attachment to the tube
    Jan 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
    STEAM BUGGY PARTS
    Hi, try to purchase on amazon Chemical Free Whole Home Steam Cleaners. If can't find exact part, you can contact sellers (probably someone can provide parts) Hope this was helpful.
    Dec 09, 2008 | Tristar SB Steam Buggy Vacuum
    We purchased a Hoover Steam/Vac (F5915-900) cleaner. We assumed it be a combination STEAM and Vacuum machine. Where is the Steam? I will await your reply. Thank You.
    http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761645
    Generic problem for all Vacuums
    Posted by hjopmi on Jul 09, 2008
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I have a similar Hoover “SteamVac” and the vacuum does not create steam as you stated, but you do have to use the hottest water with cleaning solution and the Hoover will clean your carpet by spraying down the solution, the scrubbing brushes will loosen the dirt and the vacuum will pickup the excess water until the holding tank is full and then you have to empty it, and then start again. The word “Steam Vac” is something that the Hoover factory labeled but so far I have not seen anything that actual produces “Steam” while cleaning. Feel free to contact the Hoover factory with your complaint @ the information listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    http://www.hoover.com Telephone
    Contact our Customer Service Department at 1.330.499.9499
    Monday through Friday
    8 a.m. - 7 p.m. EST
    Thanks, Don the Vac Man
    Go Ahead. Use Us.
    Jul 09, 2008 | Vacuums
    All terrain steam vac
    Try and trace the hose back from the brushes to the pump. The hose could either be disconnected, kinked, or clogged.
    Good luck - Tech101
    Jun 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
    Hoover Steam Vac Clean Surge
    http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
    Posted by just a brat on Feb 22, 2008
    I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
    The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    8 a.m. - 7 p.m. EST
    Don – The Vac Man
    Go Ahead. Use Us.
    Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
    Polti Vaporetto 2400 Canister Steam Vacuum Logo
    207 people viewed this question
    Top Polti Vacuums Experts
    Billy Detlefsen
    Are you a Polti Vacuum Expert? Answer questions, earn points and help others
