Question about Smeg Dishwashers
SMEG DI 612CA. Dishwasher
SMEG DI 612CA. Dishwasher was working fine finished cycle. Put on another cycle seemed to start okay with double bleep, then about 2 mins after it has started it sounds three bleeps and the cycle stops and nothing has been washed.
Machine now goes to start and then all you here is a humming noise - the 3 bleeps
Pisss!!! Comin from my asss!!
Posted on Jul 24, 2008
My smeg di 612ca dishwasher door will not shut.any ideas?
Check that nothing is protruding from inside of machine. If still won't shut check that nothing is stuck in the closing mechanism. As a last resort contact manufacturer or service agent.
Aug 11, 2014 | Smeg Dishwashers
My smeg dishwasher seems to be permanently in wash mode. The light on the menu of settings no longer flashes, but permanently is on, and when I run a load it never stops. I hear the two beeps as if the...
You have a timer relay issue ,probable need a new board for it ,a cheap fix would be to time it and see how long it take to run full cycle and put a regulaer outlet timer on it or a alarm off your stove or what ever,save a couple of bucks
Feb 16, 2011 | Smeg STX2 Dishwashers
I have a candy cdi 3515 and after about 1/2 an hour into the programme it stops and a continuous alarm bleeping starts.
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Oct 11, 2010 | Candy Dishwashers
Machine won't drain fully
If the drain pump is working fine, and water flows from the machine and there are no clogged drain lines, then the problem is usually the water level sensor.
This is usually a floater sensor located on a side inside the dishwasher.
Check if water level is working properly, if the floater is too low then that is the problem.
Apr 07, 2009 | Smeg CSU2001 Built-in Dishwasher
Smeg DI 612 C Domestic Dishwasher
I was told by a SMEG engineer that I needed to replace the detergent dispencer. Just waiting for him to get back with a new one.
Aug 15, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
Dishwasher Whirpool not finishing a cycle.
control board issue needs to be looked at by whirlpool tech in your area, still under warranty
Apr 10, 2008 | Smeg PLA8743XU Full Console Dishwasher...
Smeg DI 612CA
Take a look at this link http://www.smeg-service.co.uk/support/index.php?a=1&cat=4
Would seem to be the anti flooding device on the inlet hose
Nov 19, 2007 | Smeg 24 in. STX2 Built-in Dishwasher
It's stuck on Bio...
Here is the link to the user manual, hopefully this solves your problem else please ask again; http://www.smegtech.com/site/smeg/pdf_libretti/19590097802-GB.pdf Hope this helps :)
Jun 25, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
Feb 02, 2007 | Smeg CSU2001 Built-in Dishwasher
Dishwashers Logo
744 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
