Question about Acer AL2671W 26 in. LCD Television
Acer LCD Monitor AL2671W - screen too bright!
My Acer AL2671W LCD TV video is terrible. Too bright a screen. I have the DVI (for VGA only) and VGA ports working but the picture is still bright. I have sound on all input connections but I'm missing TV on the TV Tuner input. Just the sound is working there. I have to hard boot the TV/Monitor to get it going as well. With all of the video adjustment turned to the lowest level, I can use it as a PC monitor. I have never used the TV Tuner until now preferring to use a SAT Capture Card for my Video. What part could I replace to get the screen toned down so it doesn't look like the sun on the default setting!
I also have never been able to get the DVI-D input to work using two vid cards, currently using the Geforce 7300. Thanks.
  • Glebular May 17, 2008
    I have also never been able to connect a video card to the TV. The video card output is DVI-D. The TV input is just DVI. I tried an adapter between the 2, and no success.
    Does anyone else have this problem?
I had the same problem with my TV when I purchased it used. Select the input you are having troubles with and enter "Service Mode" by pressing and holding the "VOL - " button and "CHAN + " buttons on the TV, simultaneously until the screen flashes red one time.
At this point you will be in service mode. Pressing the "MENU" button will open a service menu, which is different from the typical user menu. From the service menu you can further adjust your image settings until you have a decent picture.
Initially my VGA input looked terribly bright and washed out. Now it looks incredible!
Posted on Nov 23, 2009
Right click on the desktop screen and click on Properties, then Settings, then Advanced..then the Color tab;.you can change the brightness here!
Theresa
Posted on Apr 23, 2008
I connected my acer monitor to my dvd - screen appears the switch to amber light black screen
What kind of the adapter are you using to connect the DVD video output to the monitor VGA/dvi INPUT? Need more information.
Mar 26, 2011 | Acer AL1916W 19" LCD Monitor
My monitor is blank, the Acer logo will flash on when I start it but cannot get a signal, have tried it on another machine same response.
I am not too sure if you have tried this but this might help, for what i know your monitor have 2 ports for video (DVI and VGA). VGA is the one with color blue adapter, while the DVI is white. If your using VGA for both computer might be you can try DVI or from DVI to VGA. Also try a different cable for both VGA and DVI. If still the same might as well contact the Acer and check the warranty, normally monitor had 2-3 years of warranty, Have it replace if still under warranty.
I hope this works on your issue.
thank you for choosing Fixya.
Mar 06, 2011 | Acer V193W 19 inch LCD Monitor
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
How can i use my acer monitor as a tv i lost my manual
The manual won't help you to much in this regard.
This monitor is a standard type that has both a VGA and DVI input.
Normally what you would use with a personal computer.
If you want to use it as a TV monitor you will have some sort of device that outputs to VGA or DVI.
DVI stands for "Digital Visual Interface" and it's preferable over VGA as it should potentially give you a better image.
This means:
A) A computer. You can build your own media TV and watch internet streamed shows like Hulu, Netfix, use as a DVD player, etc. I recommend this route. No more dependance on Cable companies! You just need internet.
B) Find a DVD, and, or Tuner/Cable/Satellite box that has these outputs.
If you want to use Cable or Satellite, contact your provider company and see if they have a box that will output to either VGA or DVI. Might have a hard time finding one of these, or it might cost more then it's worth.
C) Buy a S-Video input to VGA/DVI output. You can buy these for around $40.
Then you should be able to hook it up to just about any device as most modern TV devices will have an S-Video outputs.
Feb 17, 2011 | Acer AL2032WD 20" Flat Panel LCD Monitor
Are acer monitors unable to pick up HD video inputs?
There are two types cable to connect to LCD Monitor. VGA and the other is DVI,ight need DVI cable it has flat pins and is larger than the VGA small round pin models.
Dec 21, 2009 | Acer X193W LCD Monitor
My Acer P205H shows up for 1-3 seconds before showing a black screen. Connected DVI Cable but is there a need to connect vga too?
Depending upon the video port/s you have on the graphics card, you need to connector one video cable, either the DVI or the 15pin DSub to the monitor.
Sep 12, 2009 | Acer AL1916W 19" LCD Monitor
Problem connecting DVI input of TV to DVI-D output of video card
For error code 0122, Don't play the movie or load your movie program until you have the resolution you want and have it set to display only on the hdtv . You do this by going to control panel, selecting "adjust common used mobility settings", and then clicking on "connect display. A pop-up will come up and give you the option to display only on the external display. Pick that. The thing that sucks is if you have the display set to 1920 x 1080, you can't see everything on your desktop when trying to view it on the tv.
May 17, 2008 | Acer AL2671W 26 in. LCD Television
ACER LCD Monitor display is too bright!
I have my husband's hp monitor and thought I was going to go blind. I turned down the brightness to 0 and it still didn't help that much. I decided to turn down the contrast and it worked. Hope this helps.
Mar 04, 2008 | Televison & Video
Acer AL2671W 26 in. LCD Television Logo
2,009 people viewed this question
Top Acer Televison & Video Experts
Gareth Cockram
Gareth Cockram
Rommel Balcita
Martin Murray
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
