ROUTER having a problem with router, can't seem to get it to work like i want to, do you have to use the same network on both computers. I want to reset password and user for my router, i need some help.I have bellsouth on my desktop and i'm using yahoo on my wife's laptop is this possible and do i have to set-up the linksys on the laptop. when i try to set-up the linksys router on my desktop it want's me to login there and i don't want that on my desktop--need some info, contact ronedwards@bellsouth.net
    Genius:
  • 3,587 Answers
If you want to see the linksys on both machines, you'll need s/w on each of them, yes.
Posted on Mar 04, 2008
I just got a NETGEAR n600 dual band router, ran the resource cd to set up the network, and everything was successful. Whenever i connect to the wireless network my computer says its connected to an...
My Friend ,
Seems that the router is producing the wireless signal the problem is only with the computer.
What i can suggest you is to delete all the wireless networks from the list and then try to add the network again.
Dec 09, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
Wps54g wireless failed to connect but works with the ethernet cable Both the print server and the Router are linksys (router= wrt54g) I have all the cds and everything that came with them but nothing...
It sounds like you are using a router, then using a router in series with it. The two networks will most likely not be seen between computers hooked on different routers, although you should be able to get to the Internet. If you need more ports, get a switch instead of a second router. To make the printer work with what you have, use the wireless printer on the same network (that is, from the same router.) If you need the second router for more area coverage, get an extender.
Sep 29, 2017 | Linksys Computers & Internet
We have 2 computers networked through a router. I have just got a new computer and when I try to connect to the network it asks me for a security key. What is this?
It would seem that your network is actually wireless. What you could do is double check the security key for your wireless network on your router or you could check the other 2 computers, if they are connected wirelessly, for the security key. Then use that security key on your new computer.
Apr 28, 2010 | Computers & Internet
We recently installed a new replacement router WRT 160N V3 and something called Network Magic keeps interupting and trying to sell their service. We keep canceling them and then the router does not work...
To clear out the problem if Network Magic has something to do with your connection.
1) Uninstall Network Magic from host computer.
2) Remove Ethernet connections to router.
3) Reset the router (press & hold reset button for at least 15 secs.)
4) Run Setup wizard on host computer and follow on screen instructions on connecting PC to router.
5) Setup wizard prompts on installing Network Magic, just ignore it.
6) if it automatically installs Network Magic just uninstall the program before you fully use your router.
Resetting router clears all settings made by Network Magic application made on the router.
Hope this helps.
Mar 13, 2010 | Linksys Wireless-G WRT54G Router
No wireless internet - problem with belkin router
From one of the "wired" computers, connect to the router's built-in web-server, and run the "Wireless Networking Setup Wizard", in order to configure your wireless network, choosing an 'SSID' and a "password" for your network.
Dec 28, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Router QoS / prioritize internet usage on a network ??
i can confirm that QoS is in D-link DIR-615 router [newest firmware. i use it myself and its great
Sep 13, 2009 | Linksys Wireless-G WRT54G Router
XP laptop connects to router, but connection doesn't work
first thing you may want to check on will be from your computer.
since you are using windows XP just browse for the available wireless network then click on "Change the Order of Preferred network", once you are in, remove the Belkin SSID from the list and other networks that has to do something with Belkin.
Next step is to changing the SSID and the channel of your router and get it encrypted. Start with WEP, and once you have it connected, work your way up to WPA to get more security. just make sure that your XP has the WPA patch, but since you have SP2, you may have it on.
hope this helps out. if you have other questiosn just lemme know.
Nov 02, 2008 | Belkin (F5D8231-4) Wireless Router...
Wireless router signal
I suggest that you move the router around to find the strongest signal for you computer or if your computer has a small antennae try moving that fround for the best signal
Lou Margolis
Allied Electronics
Aug 14, 2008 | NetGear WGR614 Wireless Router
Unsecured network shows up as secure
The person who has the router attached to there computer must enter the IP for the router and you will be able to reset the password to enter the router. If you need Help doing this I can solve this issue with you through my computer.
Hope This Helps
All The Best,
RCF
May 28, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
No wired connection
Firstly dissable your wireless adapter, as the router will try to allocate the same ip address to your pc twice, and this is not allowed. You need to check that the wired network card is set to obtain an ip address automatically, go to control panel>network connections right click on the network card icon>properties in the TCP/IP click properties again. restart pc, type 192.168.0.1 in your web browser and you should be able to get into the routers settings.
Sep 21, 2007 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
