ACER LCD Monitor display is too bright!
My Acer AL2671W LCD TV video is terrible. Too bright a screen. I have the DVI (for VGA only) and VGA ports working but the picture is still bright. I have sound on all input connections but I'm missing TV on the TV Tuner input. Just the sound is working there. I have to hard boot the TV/Monitor to get it going as well. With all of the video adjustment turned to the lowest level, I can use it as a PC monitor. I have never used the TV Tuner until now preferring to use a SAT Capture Card for my Video. What part could I replace to get the screen toned down so it doesn't look like the sun on the default setting!
I also have never been able to get the DVI-D input to work using two vid cards, currently using the Geforce 7300. Thanks.
I have my husband's hp monitor and thought I was going to go blind. I turned down the brightness to 0 and it still didn't help that much. I decided to turn down the contrast and it worked. Hope this helps.
Posted on Jan 05, 2009
VGA To HDMI ?
Here you go. Some very inexpensive and they work well.
https://www.amazon.ca/s/ref=nb_sb_ss_i_2_11?url=search-alias%3Delectronics&field-keywords=vga+to+hdmi+adapter&sprefix=vga+to+hdmi%2Celectronics%2C145&crid=1HJZTZOV9K2UA
Oct 08, 2017 | Acer AL1912 19" LCD Monitor
Im not sure if i am supose to plug the dvi-d in cord in and the vga-in cord to
Your video card needs to have DVI output port for you to use the DVI cable, otherwise you can just use the VGA cable.
DVI is supposedly t give better pictures due to all digital signals compared to VGA which is analog.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 21, 2010 | Acer 22" X223w LCD Monitor
I cant connect my acer aspire 5810 tg with my samsung lcd tv.the tv say "NO SIGNAL"
So here's a quick walk-through of all the methods that I know (if you know any more, please comment) to connect a laptop or PC to your TV:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with "digital" being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here's a graphic I created with some pictures of the various cables:
Hope this helps someone! If you have any other ideas or suggestions, please feel free to comment!!! Thanks!
Nov 13, 2010 | Acer Computers & Internet
Link my acer aspire 592o laptop to my panasonic plasma
1. S-Video – This is probably the most commonmethod out there currently because an S-Video cable is cheap as heckand just about every TV under the sun has a S-Video port. You’ll haveto make sure you laptop is equipped with this port. Remember, there aretwo types of S-Video cables: 4-pin and 7-pin. Mostlaptops and PC’s are equipped with a 7-pin port, so if your TV only hasa 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will bebetter off connecting using a VGA cable. It gives much better qualitythan S-Video and as with S-Video, the cable is very cheap. You usuallywon’t find a VGA port on regular TV’s though, so this option is if youhave an HDTV.
3. DVI - DVI stands for Digital Visual Interfacewith “digital” being the key word there. The digital signal will give ahigher quality picture than either S-Video or VGA. Of course, yourcomputer will need to have a DVI connection and your TV will need to bean HDTV. This cord is definitely not cheap, it ranges anywhere from $40to $80.
4. HDMI – Using HDMI will give you the best qualityby far. No computers that I know of yet have HDMI ports, but you canget a DVI to HDMI cable to connect it to your HDTV. HDMI is compatiblewith DVI.
5. Scan Converter Box – This is the last methodthat I could think of and it involves using a scan converter box, whichtakes a VGA signal and converts it into S-Video or component video.
Here’s a graphic I created with some pictures of the various cables:
Jan 26, 2010 | Acer Aspire 5920-6335 Laptop
Acer flat screen tv - sound no picture?
Acer AL2671W 26in problems: (1) sometimes sound but no picture, (2) or screen freezes pink etc. (3) or remote won't turn it on/off (4) or it gives up and says "no signal". Turning it off/on usually solves it temporarily.
Nov 17, 2009 | Acer AL2671W 26 in. LCD Television
No reboot and no screen.
hi jsc,
try to use the VGA port again so that we can isolate the problem. hold the power button down for more that 5 seconds.
Jun 18, 2008 | Acer Aspireā„¢ T180 PC Desktop
Nvidia GeForce 7200 GS PCIE - Multi-Display does not work
This card does not allow you to Multi-Display with the VGA port and the S-video port. If you put a DVI to VGA port adaptor (not supplied) on the DVI port, you can Mulit-Display two VGA monitors and (presumably) a VGA (from the DVI port) and S-video monitor.
This is not explained anywhere and the card does not come with a DVI to VGA port adaptor, so I wa only able to work this out after I bought the DVI to VGA port adaptor.
May 21, 2008 | Nvidia GeForce 7200 Graphic Card
Connect desktop PC w/ DVI and get a red screen
Fixed my own problem lol. Video card needs to be replaced.
Apr 25, 2008 | Protron PLTV-32 Television
Acer LCD Monitor AL2671W - screen too bright!
I had the same problem with my TV when I purchased it used. Select the input you are having troubles with and enter "Service Mode" by pressing and holding the "VOL - " button and "CHAN + " buttons on the TV, simultaneously until the screen flashes red one time.
At this point you will be in service mode. Pressing the "MENU" button will open a service menu, which is different from the typical user menu. From the service menu you can further adjust your image settings until you have a decent picture.
Initially my VGA input looked terribly bright and washed out. Now it looks incredible!
Mar 04, 2008 | Acer AL2671W 26 in. LCD Television
Screen prob.
For flat panel systems there are 2 inputs. DVI using the white cable and VGA. by default flat panels are set to DVI input. hit the menu button on the screen and there should be an option there to change the input video. if this will not work it could be a problem on the video port on your acer computer or it could you might need a new VGA cable.
Oct 11, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Televison & Video Logo
1,394 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
