Dont know what size bolts to use for fixing brackets to tv to wall mount a 26 inch wharfdale l26ta6a
  • 552 Answers
You should use minimum of 1/4" lag bolts by 2'" long.
Find a wall stud, and drive the bolts(one above the other into the wall through the mounting bracket holes.
Posted on Mar 04, 2008
Screw size for wall mount 32 inch model TDE3253
Bolt size is M6 bolt pattern and thread pitch. A 15 to 25 mm long bolt is recommended depending on the thickness of the wall bracket.
I got got this from GPX. If you email them you can get the full TV guide.
Apr 18, 2014 | GPX TDE3282B 32" 720p LED HDTV/DVD Combo,
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
What wall bracket do i need for my wharfdale 42'' plasma tv, model number w42s40pe
Check for 3 things, 1 location on wall ( you need to attach it on a wooden stud in the wall, 2 weight and size ( you want a mount that usually sized for 40" to 48" or 50" inches which will accomodate for the weight, 3 One that Tilts ( get one that will at least tilt up and down, due to the reflection of any lights or sunlight. also because you may need to adjust it so that you can see it from a seated position.. other than that any brand will do, more you pay the better (and easier) they are to put up... Good luck
Mar 24, 2010 | Televison & Video
Screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Dec 23, 2009 | Televison & Video
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Aug 23, 2009 | Televison & Video
What is the correct wall mount for this tv? and cheapest too! westinghouse sk26H730S tv (26 inch lcd tv)
You dont need a correct one you just need one wall mount that can fit 26 - 30 inch search wall mount on trademe or ebay realy cheap and they can ship it down to you thats the cheapest way
Aug 01, 2009 | Westinghouse Electric SK-26H730S 26 in....
Removing the stand on Insignia LCD 26F TV
My insignia 26 inch dvd combo TV stand can be removed by removing the access cover to your input connection. There are eleven black phillip-head screws. The three bottom screws also hold the plastic base cover in place. Remove all eleven screws and pull the stand out from below. The four philip-head screws on the back center of the TV is for the location of the wall bracket mount. Good luck.
Jan 26, 2009 | Insignia LCDTV26 26 in. Television
Looking for wall mount for MLTD2622 26" tv
I had similiar issue with 32 inch...bracket required an adapter which I found through Best Buy. Check out Sanus.com They should give you discription of what you need and tell you where to get it. Adapter was very cheap ($19.00 or so). It is essentially two metal bars that bolt to regular wall mount, the bars will line up with bolt holes on TV.
Dec 13, 2008 | Memorex MLTD2622 26 in. LCD TV
How to mount the 26" tv on a swivel wall mount?
No dont do that ! you will need to buy a wall mounting unit...you can find at best buy wall-mart and other electronic stores!
Dec 11, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Televison & Video Logo
167 people viewed this question
Top Televison & Video Experts
