Hello sir I am having the same problem you had with your Phillips. Pretty sure we have the same model. Are you sure it was an IC chip problem and not just an issue with the capacitors? Also, do you know which capacitors are the one in questions? Thanks!
  • 148 Answers
Hi there, If you'd like to diagnose your own tv for bad capacitors, then you can follow these, guidelines...If you don not see any bad "popped" capacitors, only then would I replace the ic...hope this helps!..Please arte if it did (or did not ), thank you!The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! hello sir - fcda6dc.jpg
Posted on Feb 06, 2010
I am not sure if it was one of the capacitors or the IC chip. I decided that since I had it opened and was removing the some components anyway, I decided the replace all the capacitors and the IC chip. The guy I purchased the parts from said that the IC chip was the #1 most failed component.
Posted on Mar 04, 2008
  • Husch Mar 04, 2008
    Here is the link from Ebay.http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...
    sorry, I guess the URL is too long. Search for this on Ebay and you will find it.
    Philips Plasma TV Power Supply Board - Repair Kit DIY (#330215700814)
Plz sir tell me solution....my Intex notebook model no m73sr vga ic chip shot ..how can i get new vga ic SIS M672
Let's see if this works as a direct link,
http://www.alibaba.com/showroom/sis-m672-bga-chipsets.html
If not copy the above URL, paste it in your address bar, (http://), and press the Enter key.
http://www.youtube.com/watch?v=3NN7UGWYmBY
Regards,
joecoolvette
Apr 22, 2013 | Computers & Internet
Display problem
Hello Sir/Madam,
Its becoz of <IC> chip which continue when you slide up and down. Their is only problem of IC. Change it and it cost 300rs in India and convert it your currency.
Thanks
May 25, 2010 | Samsung SGH-E251 Mobile Phone - Black
Display Problem Model E251
Hello Sir/Madam,
Its becoz of IC (Little chip which provide continue funtion when you slide up and down) Change only that one in repair shop and its cost 300rs in India and convert it to your currency.
Thanks
21pt2216/94 phillips 21'' audio problem
your speaker maybe busted or check the amplifier IC
Oct 22, 2008 | Televison & Video
Phillips Magnavox 60" model ptv835
Recently had same issue and after EXTENSIVE SEARCHING found all three ICs and replaced them. TV works perfectly, also, replaced convergence ICs at same time. The one 16-pin IC for the regulation ckt. is $49.95 the other 16-pin IC is $19.95 and the 8-pin opto is about $10. This price is for a minimum qty. and must have a business for quote.
Aug 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
Dell Keyboard Encoder IC KKMPA80604 Data Sheet
Hello sir i'm student of 2nd year i am study on ic635 silitek mpa20604 so please help in understand of datasheet of this keyboard ic sir sorry if i'am type wrong grammtical english, beacuse sir my medium is hindi.
May 03, 2008 | Dell Silitek SK-1000REW Keyboard
Phillips 60pw9363 Which IC is red and which is blue
Thats the DPTV 335 series chassis when the IC blows it will usually take out 1 or 2 6.8 ohm resistors along with it. Look at the resistors right next to the ICs you will notice 1 or 2 with a little discoloration in the middle replace those and your set should be back to working just fine. Let me know if you need more help. These resistors are easy to spoy they all look alike and shouldnt have any bands on them they will be stamped 6R8 ohm 1W J
Apr 12, 2008 | Televison & Video
Repair of Phillips 21GX 1563 94R TV
replase the capaciter 100mfd 40v located near vartical out put ic.
Mar 09, 2008 | Televison & Video
Televison & Video Logo
580 people viewed this question
Top Televison & Video Experts
Electro Med Services...
