Question about Oster 5838 ExpressBake Bread Maker
Oster breadmaker model 5814
I need the ring between the drive shaft and the mixing blade (paddle). I've been told I have to replace the entire pan, but that model has been discontinued. Where can I find a replacement pan?
  • Anonymous Mar 30, 2014
    ran it through for 2lb loaf medium crust. The machine ran through the complete cycle but the ingredients were never mixed. they were still sitting in the pan in the manner in which they were put in. We than ran it through a jam cycle and the same results. the ingredients were not mixed through.
I just bought a pan and paddle from ebay and I do not need the pan. I can see it to you if you like.
Posted on Jan 23, 2009
  • 552 Answers
There is a 5838 machine selling on ebay slitely used about 5 times for $20.00 right now.
This may be a good route to take.
Parts are difficult to find.
or go to www.oster.com and give them a call.
Posted on Mar 04, 2008
Can you tell me where I can get a manual for a oster model 5814 bread machine?
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=78a82d448ccb83fe38c52f95347a2a4f&modelid=905223&q=Oster+5814
Jul 29, 2012 | Oster Kitchen Appliances - Others
I got a used oster 4812 bread machine from a friend. Making my first batch of bread and it seems the paddle is struggling a bit and there are occasional "squeaks" as if the internal gears need a...
Your drive belt is slipping dear. You'll need to pull the bottom cover off and replace it. Belt are sold here: http://www.amazon.com/Sunbeam-056386-Oster-breadmaker-belt/dp/B000238A34
Also perform these services for best results:
Servicing Your Automatic Breadmaker
For best results perform the following services annually.
Warning: Use only Lock-Ease Graphited Lock Lubricant for the following services. Other lubricants tend to damage the seal and/or gum-up the drive shaft. To purchase your squeeze-bottle version of Lock-Ease Graphited Lock Lubricant go online or visit your local Ace Hardware or NAPA Auto Parts Store.
Lubricating the Pan Shaft with Lock-Ease:
Remove the bread pan insert and place it upside-down. Apply Lock-Ease to the top of the pan's coupler. Gently rock and rotate the coupler to allow for penetration. Repeat 3 times. Allow to air-dry 1 hour. Wipe away any remaining residue.
Lubricating the Wheel Shaft with Lock-Ease:
Access the electric motor/drive wheel platform. Check that the screws securing the electric motor to the platform are good and tight. Do not lube the electric motor.
Jun 12, 2011 | Oster Kitchen Appliances - Others
I have toastmaster model 1193..as it mixes the dough it makes a grinding sound- the shaft and the mixing blade are worn. how /where can I get replacement parts for this. We LOVE the machine and hate to get...
You can often find them on ebay at reasonable prices. I have an older model toastmaster that is almost new if you are interested let me know. Sometimes you can find the pan and paddle assemblies up for sale and/or auction there also.
Dec 08, 2010 | Toastmaster Breadmaker's Hearth 1193 Bread...
The agitator turns very hard - like it is stuck partially siezed. Model 5838
Hi..The sealed bearing that the paddle shaft rotates on is starting to fail. Soon it will freeze up entirely and you will need a new bread pan. Fill the bread pan half way up with hot water a few times and see if you can free it up to "buy some time" Hank
Dec 05, 2010 | Oster 5838 ExpressBake Bread Maker
I have an old toastmaster bread machine model 1154, and I realized that the kneading blade does not rotate when the ingredients are in the bread pan. Either the kneading blade mounting shaft and the...
If the spindle is turning and the paddle is not then your paddle is worn out and probable slipping on the spindle. If the spindle isn't turning then your problem is underneath the pan or inside the drive and your paddle may be fine.
Dec 01, 2010 | Toastmaster Kitchen Appliances - Others
Drive shaft no longer turns kneading blade on model k6725
Either the paddle is frozen in the bread pan ( take pan & paddle out of machine and see if you can turn it by hand), or the belt has fallen off or has snapped. (Keep the bread pan out of the machine & run a knead cycle, look through the lid window and see if the motor shaft spins. Hank
Mar 05, 2010 | Regal Ware Kitchen Appliances - Others
Mixing paddle won't turn.
The mixing paddle is supposed to turn by means of a lubricated bearing. This bearing is broken or stuck so the blade will not turn.
Try soaking it overnight in soapy water. If that does not work it's time for a replacement pan if you can find one.
Hank
Oct 04, 2009 | Sunbeam 5833 ExpressBake Bread Maker
The mixer blade won't mix. The motor runs but blade won't go.
Take the pan out of the machine with the paddle attached and see if you can spin the paddle freely by hand. If you can that's great. If you can't then the paddle is stuck or the bearing is broken.
Then, with the pan out of the machine start it up and look through the lid . Check to see if the shaft where the bread pan and paddle usually goes is spinning. If not then check to see if the drive belt inside the machine fell off or if it needs to be replaced.
Hank
Sep 14, 2009 | Oster Kitchen Appliances - Others
Oster 5814 motor does not operate
I replaced the overheat switch in the motor coil it went bad after the mixing paddle froze up.
Dec 02, 2006 | Oster 5838 ExpressBake Bread Maker
Oster 5838 ExpressBake Bread Maker Logo
631 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Hjalmer Lamminen
Hjalmer Lamminen
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
