Question about Quantaray 28-200MM F3.8-5.6 Lens for Canon AF
Attachment for filter and hood
i have the quantaray tech-10 28-200 for minolta, i lost the ring for the hood and what not, i have a 72mm hood and cap for it but the actual glass is smaller, do you know where I can by a replacement adaptor?
    Scholar:
  • 39 Answers
If you go to the camera store that sells quantaray then they will be able to order you one if they do not have it in stock.
or you can find one on a online auction site.
you need a step down ring. I believe the size of your lens is 58 mm but you could go to any camera store and ask them to verify that. but it should also be stamped on the front of the lens written in white.
if you find 58 mm anywhere on it then I am right. And that means you need a 72 to 58 mm stepping ring.
hope that helps,
Caleb
Posted on Jul 02, 2008
I have a Quantaray 28-200mm AF zoom lens Nikon, I use Nikon D80, are they compatible?
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as with a lens without an aperture ring.
Jul 14, 2014 | Quantaray 28-90mm F3.5-5.6 Autofocus Zoom...
FEE message using Quantaray for Nikon lens
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as on a lens without an aperture ring.
Jan 26, 2013 | Nikon D Cameras
Quantaray 70 - 300mm for Minolta AF (25-166-4546)
Check you manual, but it should be no problem- Sony bought Konica Minolta to have the Minolta lens mount (and engineers). Your old lens doesn't have all the internal electronics (and connections) of the new lenses, but every old minolta AF lens i've tried works fine with alpha
May 02, 2010 | Quantaray Tech-10 70-300mm f/4.0-5.6 Lens...
How to use auto fouse
The D40 does not have a focus motor, instead relying on a motor in the lens. This lens does not have such a focus motor, and thus will not autofocus with the D40.
Dec 25, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
72mm closeup lens set: glass is loose from the round metal frame
Using a toothpick as an applicator, I would carefully place three very tiny dots of 'Superglue' equally spaced around the circumference.  The regular (thin) type creeps very well and will partially fill the void between glass and ring. Make sure the lense is free from any finger-oils or other contaminents that can prevent bonding.
May 06, 2009 | Quantaray Filter
Is the quantaray 55mm lens hood compatible with a d40
yes and no. no because the lens diameter of the 18-55 is 52mm and yes if you use a stepping ring that you screw on the 18-55 to accommodate the 55mm hood.
Feb 22, 2009 | Quantaray Cameras
Used on a Minolta Maxxum 800 si
Hello
The Minolta AF lens will fit and work on most of the Minolta AF bodies (it will depend on exactly what lens it is as to the compatibility), you will also find that it will fit and work with the new range of Sony
digital SLR camera bodies.
The Quantaray lenses are a little bit more difficult as Quantaray make lenses for several different types of camera body, it should mention on the lens what make the lens mount is for. If you post further information about the lenses it might help.
Sep 19, 2008 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
My question is about a Quantaray 75mm-300mm
Slide a piece of paper partway under the ring (make sure you leave enough hanging out so you can remove it later) and see if that tightens the action some.
Another low-tech approach is to push the ring to expose the inner barrel, then attack one or more pieces of Scotch tape or masking tape.
Jul 30, 2008 | Quantaray 28-200MM F3.8-5.6 Lens for Canon...
Lens Hood Size
The VX2000 lens does have a 58mm diameter thread for filters etc. The 72mm refers to the focal range (Zoom) from 6mm to 72mm. The 58mmm lens hood should fit, but I strongly suggest you obtain a SONY OEM lens hood with lens cap. Goto http://www.pro-cam-electronics.com or other professional camcorder sites for these items.
Peter Jansen
Dec 11, 2007 | Sony DCR-VX2000 Mini DV Digital Camcorder
Quantaray 28-200MM F3.8-5.6 Lens for Canon AF Logo
71 people viewed this question
Top Quantaray Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
teddyboy
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
