Question about LG DLE5977 Electric Dryer
Takes a lot longer to dry clothes
I have the same problem with this Model dryer...takes a very long time to dry a load. Own this unit new, within a year had the Drum and roller replaced by LG. Six months after that, had the Blower fan blades replaced. Now it's taking a lot longer to dry clothes.....I thought it was the heating elements but its blowing heat out. Have clean out vents system so there is no obstruction.
Saw one solution was to replace the belt ?.....I will try that. Does it have to be an LG belt or any dryer belt that matches the dimensions?...
thanks
  • ace777b Mar 05, 2008
    Is there an adjustment I can make in the dryer ? look like there is a spring loaded/tensioner on it.........thx
  • kerbes Apr 09, 2008
    I've had my LG DLE5977 for two years now. It is taking longer and longer to dry clothes. Could it be the moisture sensor is going out? The reason I suspect that, is because it seems to be shutting off sooner than it used to.
    President:
  • LG Master
  • 2,651 Answers
Belts MUST be ordered by model all belts are different sizes, different witdhs
Posted on Mar 05, 2008
Dryer takes a long time to dry
there is no truth to the fact that dryer elements start to burn out there fore it takes longer to dry cloths the only reason a dryer will take longer to dry cloths is due to lint build up within the unit take the back off and vacume all the old lint out and around the heating element and it will work like new
merry christmas
Dec 21, 2010 | Maytag Dryers
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
It takes longer to dry your clothes you have to restart the drye
first clean the pip from the unit to the outsde vent.
then inside your unit there are 2 felts that need to be cahnge, over time they go bad and the heat run out the drum and you can feel the hood is hot but it still not to good . it will save you electric bill when you fix it. :)
Dec 31, 2009 | Whirlpool LER4634J Electric Dryer
We bought our maytag washer/dryer in 2007. Washer does great, however our dryer is the problem. It seems to take longer to dry clothes, than any dryer that we have had, also the clothes "ball up", which...
are u sure the belt isnt sliping somtimes if u over load or have a lot of cloths in it that will ball up the cloths and haeting problem either the vent tube is stopping up or heating coil is going out
Oct 23, 2009 | Dryers
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
WHIRLPOOL LER6620PTO DRYER TAKES MORE THAT 40 MIN. TO DRY A LOAD OF CLOTHES. WAY TOO LONG
Hi, you are correct. this drying time is quite long. i recommend checking the following areas on your unit to combat this issue. the most common issue here will be a clogged vent hose or blower housing obstruction.
Check the following---
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 17, 2009 | Whirlpool LER4634J Electric Dryer
Longer time to dry clothes
Remove the rear connecting vent and run a 45 minute timed dry load. If it works correctly repair the connecting vent and or blockage in the wall.
If this does not correct the problem make sure the glow bar is cycling at the gas valve and report back for further repair.
Apr 12, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer
Dear sloika,
I do not believe the problem lies within the dryer unit.
when the dryer unit fails to dry clothes in reasonable time 90% of the time it is the clogged air vent is the reason.
Dryer vent cleaning improves the safety and efficiency of your dryer installation. As dryer vents become filled with lint and other debris, drying time increases and can cause the dryer itself to overheat. This increases energy consumption since the dryer has to run longer to dry your clothes and can also cause fires in the dryer or the dryer duct. The Consumer Product Safety Commission reports dryer related home fires are on the increase.
  • First check your vent hose between the back of dryer and the air outlet on the wall. Vaccum clean the dirty hose and even into the dryer unit using flexable vaccum attachment. also try to vaccum clean airoutlet that goes into your wall as far reach into and much as possible. The dryer's lint filter and its path needs to be cleaned as well.
  • If all air flow path are cleaned it will improve 200% of your drying time.
There is also professional dryer vent cleaners in your area who can help solve the problem. just check your yellowpages..
Feb 16, 2008 | Dryers
Dryer sometimes works other times doesn't
Check and make sure there is not lint build-up in the venting hose leading to outside. This will cause longer drying times and can be a fire hazard. Also, if you use the Aluminum venting hose instead of the white plastic it can cut up to 30 min. off your drying time. It is a lot safer then the white venting hose which can also be a fire hazard. Make sure all the lint is cleaned out from the inside of the dryer where the venting hose is connected. It could be a clog there. This sounds more like the problem since the clothes are actually drying but it could be a partially burnt out heating element. Good Luck.
Dec 16, 2007 | Frigidaire FEX831CS Top Load Stacked...
LG DLE5977 Electric Dryer Logo
222 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
