Question about ASUS A6U Notebook
I want to use plasma tv as external monitor
I want to use my Panasonic viera plasma tv as a monitor for my notebook. The tv has a pc input (standard 15 pin). I've plugged in the moitor cable from the laptop to tv but the tv says there is no pc signal. What am I doing wrong. Can anyone help
  • Palmbeach
    Palmbeach May 11, 2010
    You may need to install a driver on your pc. Check the tv handbook and see if this is required
    Sergeant:
  • 300 Answers
Your laptop is not set to enable the external video output.
Most likely, your laptop has a key that says "RGB/LCD" or something similar on it. This key cycles through the various video output options, enabling the laptop's LCD, the external RGB output, or both simultaneously. Most laptops require you to hold down the function key ("FN") when pressing the "RGB/LCD" key to cycle through the options.
Posted on Mar 04, 2008
Plugged in USB device on Panasonic vierra gave me overload warning screen went haywire. Now it won't turn on . no blinking light though
usb overcurrent error message on plasma tv - PC World Forums
pressf1.pcworld.co.nz > Forum > PressF1
Jul 4, 2012 - 10 posts - ‎5 authors
we have a panasonic viera tv ( plasma) when i plug in my 1st portable ... Since thedevices are not powered the overcurrent warn isn't from external sources which leadsme to think there is a physical problem with the 2nd drive. ... for the TV doesn't work, try getting firmware for the drive from WD's site, that ...
How To Use DLNA And External HDD On Your Viera TV ...
? 4:08
https://www.youtube.com/watch?v=JqeLDaB5nvQ
Feb 9, 2011 - Uploaded by PanasonicUK
http://www.panasonic.co.uk/ How to setup and use the DLNA andUSB HDD functions on Panasonic Viera TV's. ... Is there not any way to access an external hard drive without recording ... I can record using the HDD but it doesnt let me record SCART or HDMI, why is this? ... Anyone have the same issue?.
Dec 25, 2015 | Panasonic Televison & Video
Hello, I have a 2 years old Panasonic Viera plasma TV and there are many horizontal lines going from the top of the screen to the bottom... No matter which input is used...
You're discussing about the 'supply HUM' I assumes. Check all the external connection to TV inputs for firmness first. If all are found OK, check by replacing all the filter capacitors at its main power supply regulator board. In fact, replace the power supply board as card basis will be the best. For more information go to http://electronicshelponline.blogspot.com/
Dec 05, 2013 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic Viera TH-50PZ800U monitor driver
You don't need a driver. Just connect it to your PC and choose in the TV menu correct input source.
Aug 09, 2013 | Panasonic Viera TH-50PZ800U Plasma TV
Panasoics plasma viera rv will not auto tune telling us to insert aerial already in Model TH-P50X20Z
The manual for this TV can be found here. If you are watching broadcast television, or cable TV service that does NOT require use of a set top "cable box" tuner, you would connect the coax cable from the UHF / VHF antenna or cable into the ANT cable connector on the rear of the TV as shown on page 8 & 9 in the manual.
You would then tell the TV setup to scan for available channels as shown on page 12 of the manual.
If you are using a seperate tuner - like those supplied by Cable TV, Dish, DirectTV, Satellite, etc. you should use (1) the HDMI 1, 2 or 3 inputs (HD) 720P and up; (2) the RGB inputs of AV2 for best picture quality 720P or better (HD), (3 & 4) the AV1 & AV3 (on the side next to HDMI) for 480i and possibly 480P (SD) and finally the ANT connector for 480i. If you have a computer that offers VGA jack to connect to an external monitor, use the PC connector on th erear of the TV to send it HD images.
Page 27 & 28 detail manual channel editing.
Mar 14, 2013 | Panasonic Viera TH-50PX80U Plasma TV
Just bought a 42" panasonic
On your remote, click menu, then setup, then external devices, then input labels. Here is a link for manual:
http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX80U
Dec 09, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Auxilliary audio connection
I don't expect a 2 channel amp would have a digital input such as optical. More likely you would be able to pull analog stereo (red and white RCAs) off the Panasonic and run to the JVC.
Dec 29, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic Plasma HDTV 50" Viera--won't turn on. Red light flashes 10 times followed by a 3 sec pause, then repeat 10 flashes. Have solved problem by unplugging it and plugging it back in, but that is not...
Please make sure your connectors are in the proper place.
The HDMI inputs on the rear of the TV are optimized for use with Audio/Video devices, Blu-ray Disc Player, DVD Recorder, etc.
The front or side HDMI inputs only are designated for PC. To use the TV as a PC monitor, advise customers to use only front or side HDMI inputs.
Jun 16, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
ASUS A6U Notebook Logo
380 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
