Question about Acer Aspire 5610 Notebook
Network issues OK, I seem to be having a problem connecting to my school's network. Everything was just fine, but now all of a sudden, nothing, and it works fine everywhere else on campus. I'm thinking it could be a problem with my network card, but I'm not entirely sure. I bought a new cable thinking the other one may have been defective, but still nothing. I'm currently using an Acer Aspire 5610Z. If anyone has any suggestions, that'd be great. Thanks.
    Genius:
  • 3,587 Answers
Sure...go to your network settings under control panel, and see if the network card is enabled. You may need to uninstall it from there, and then reinstall it. Make sure you have cd with drivers on it first though
Posted on Mar 04, 2008
I have a problem with my NETGEAR WNA1100 Wireless-N 150 USB Adapter. I use it with my desktop PC and a Belkin 802.11g router placed in another room. As soon as I installed it, everything seemed to work...
Your Issue can be Solved by assigning DNS address on your Computer.
>First of all change the Security on the Belkin Router to WEP Mode.
--- Remove Preferred Networks From your Computer.
- Right Click on wireless Network Connection > Properties > Select Wireless Networks tab > Remove your network From Preferred Networks Box.
--- Associate with your wireless Network.
- Right Click on wireless Network Connection > View Available Wireless Networks > Select your network > Click connect
---> Check if you are able to go online.
--- If Not Try Assigning DNS Addresses For your Wireless Network
- Right Click on Wireless Network Connection > Properties > Under this connection uses the Following Items. > Double Click on Internet Protocol (TCP/IP).
- Select Use the Following DNS Server Addresses:
- Preferred DNS Server: 4.2.2.1
- Alternate DNS Server: 4.2.2.2
- Click OK & OK again
- Now Check if you are able to go online if still No go Check if you can go online on any other wireless Com or Device using the Belkin Router If Yes it Might Be an Issue with your Adapter or there Might Be an Antivirus Installed on your com Try Disabling it.
- If this doesn't work Please do get Back to us we will be happy to Help you out... :)
Mar 21, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
Cannot get Toshiba Netbook connected to wireless network
ok. try this:
open a computer on your network that connects to the network. start -> run -> type cmd and click enter.
then type ipconfig /all
then open your laptop.. go to local area connection and click properties.
click internet protocol on the list and then properites.
click on "use the following ip"
and on the three text boxes below type the same settings as the ones that appear on the pc that you did ipconfig /all. the only differnt will be the ip address. if the pc is 192.168.0.105 you should put 192.168.0.106 or something else.
do the same with dns server.
click ok to close all the opened windows and check the new ip of the laptop
Jan 25, 2010 | Toshiba Mini NB205-N313/P Netbook
Can't connect to internet on desktop computer
Most likey the issue is with the network adapter. As it does not work even with the modem and router the card seems to be faulty.
Hope this helps.
Sep 05, 2009 | Computers & Internet
Advent 4213 netbook not connecting to wireless network
Have you entered the security details regarding your network connection into your new netbook.
Sounds like the problem.
Detect the network and enter the security key (WEP;WAP etc) and should work
Jul 11, 2009 | Computers & Internet
I have to connect the LAN cable before wireless will connect
Try going to the network control panel and disabling the local connction.
Apr 04, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
New HP laptop will not connect to wireless secure network
Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Sonicwall Internet Connection Issue! HELP PLEASE!!!
juz clear the arp entries or else change the connectivity cable from modem to firewall.
Aug 21, 2008 | SonicWALL PRO 230 Firewall
Network printing suddenly stopped working
Perhaps you might wanna try checking the IP address of the printer and see if it matches that of the ones that are mapped in each individual computer. There might be many factors in the "strange" events that have occured (PC gremlins, i call it). That should be an initial starting point.
Resetting the router wouldnt help, cause it is the router that issues different dynamic IP addresses (otherwise known as DHPC) to each and eveny node connected to the netwrok as well.
Another important thing to note is HOW these devices are connected to the router. Wirelessly? Wired connection? The fact that you can see the printer via the router means that there is no problem with the router's end, so the problem lies in the intermidiate connection from the computers to the router. Try to work on this angle. Thanks.
-Technomancer
Jun 02, 2008 | ASUS WL-500g Wireless Router (WL500GDLX)
Validating identity
it is just that the network key which is stored in the computer is not working so the 1st thing u need to do is verify the network key for that go to 192.168.0.1 from internet explorer enter the user id & password of ur dlink ( default id: admin password : admin) the go to wireless check the WEP or security key which is present their. reenter that key the computer & try to connect.
If it didn't work then go to control panel >> system >> hardware>> device manager
look for the network adepter & unintall the wireless network card
restart the computer
once restart it will automatically reintall the wireless card driver
then go to control panel>>Network Connection
right click on wireless network connection
select view wireless network connect
select ur network name & connect it will ask for the key provide the key & once u do that it will get connected & work fine
if in case u have the same problem replay back & i help u out with it & also provide all the details like which windows & network card etc
May 25, 2008 | D-Link AirPlus DI-524 Wireless Router
Acer Aspire 5610 Notebook Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
