Question about Canon imageRUNNER 400S Copier
Image runner 330s
Our copies come out with "comb like" streeks on them. Is it time for a new drum? How do you replace it? Where is it?
  • 3 Answers
My ir400 all of a sudden stopped detecting paper cassettes. And display shows empty cassettes(when cassettes contain enough paper). Only working trolley and stack bypass work. What can i do
Posted on Apr 18, 2011
Sounds like the fuser has a problem, web not advancing, bearings bad, pressure not enough
Posted on Apr 11, 2008
  • Canon Expert
  • 1,326 Answers
First of all is it black lines and dark copies or is it like strans of toner on the copies? There is a difference....... One could be the drum unit that is right next to where you put toner in, just to the left of it. It is held in by one scew. It could also be a problem with the fixing ass'y. Is the display say to empty out the waste toner and how many copies are on the copier??? These are all the things I'm guessing on.. Need a little more info...
Posted on Mar 05, 2008
How do I clean corona units on Minolta 1081 copier?
Gregory, First remove the drum unit. Then remove the Charge unit. located about the drum on the drum cartridge (Not Inside the Machine) Then remove scortron grid push the front in to release you then have access to the charge wire this model may have the Charge comb type be care the combs are sharp if they are wires be gentle and use a eraser to gentle clean the wires they are very thin. During the copy process the wire/comb applies a HV charge on the drum prior to the image from the mirrors being place on the drum before the paper arrives underneath the drum.
Jan 02, 2015 | Konica Minolta Minolta EP 1081 Laser...
Need steps in removing old toner from canon image runner 330S copier
open front cover, release developer lever at right,release feeder lever at down right corner,unscrew the centre screw at the top of the drum unit, slide out the drum unit, at the back of unit u will find a clear plastic cap remove it and empty the waste toner reverse all the process to place all togather.
Jan 04, 2011 | Canon ImageRUNNER 330s Copier
Blank sheets when Copying on the Canon Image Runner 1310.
Hello sir; I would like you to check the charge corona wire inside the drum cartridge or you just replace a new drum cartridge, before you change also check the discharge corona wire at the bottom inside the machine.
Sep 17, 2009 | Canon imageRUNNER 1310 Copier
Black Haze
It can be one of two things... It may be the drum needs to be replaced or it could be the fixinf film is ripped and damaged. It maybe the transfer unit or the developing unit?
Jul 28, 2009 | Canon ImageRUNNER 330s Copier
How to add toner
Open the front cover. Towards the right side about half way down, there is a plastic lever. This will rotate to release the Developer/Toner Unit away from the Drum Unit. Pull the Unit outwards...it should stop before coming all the way out (unless someone has removed the stopper) Please use the correct type of Canon Toner as it fits on top of the Unit and unlatches Toner cover to add the toner. (Canon Type GPR-2). The instructions should be in picture format on inside of front cover.
Jun 10, 2009 | Canon ImageRUNNER 330s Copier
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
May 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
I have a canon imagerunner 330s copy machine. I'm
Hello sir;As your descript, it seems need to replace drum blade, if they come with whole cartridge then replace whole cartridge.
May 12, 2009 | Canon ImageRUNNER 330s Copier
LIGHT BUT DISTINCTIVE DARK STREEK TOP TO BOTTOM ON ALL COPIES
you do not need to replace the copier
the cartridge has a charger wire that you can clean with a pencil erasure
Also remove glass and clean the underside of the glass and the mirror
finally
open the fuser area( exit area where you clear jams and remove the wiper / cleaner of the fusr rollers
ad reinsert
look for any lines on the rollers
when you install the toner cartridge lift the shutter that exoses the imaging drum to see if it looks ok
if it has lines on it you may have to replace it ther is a wiper (silicone that will get toner nder it and can cause the lnes
All you can do is reinsert ant try it if it persists relace the cartridge
Jan 02, 2009 | Canon PC-795 Copier
Adding Staples Image Runner 330S
depednding on sorter im guessing its the small sorter with one tray the stapler is in the rear of the sorter green handle pull it out uses L 1 staples
Jul 24, 2008 | Canon ImageRUNNER 330s Copier
Cannon Image Runner 330s
There is nothing wrong with the solenoid. The fuse cleaning web is similar to a roll of paper towels. For each copy made the copier fires the solenoid, advancing the web roll slightly. You can override the error but that will damage the upper fuser roller since it won't be cleaned and lubed properly. You need to replace (or have replaced) the cleaning web and reset the web counter in service mode. I am not sure on that model but when you purchase the web, $15-20, they can tell you how to reset it. Good Luck.
May 07, 2007 | Canon ImageRUNNER 330s Copier
Canon imageRUNNER 400S Copier Logo
old marine
old marine
