Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi rear projection tv white screen goes dark and....
I bought my tv a year ago and it was acting up a little when i bought it. i have to leave it on all the time because if i dont the picture will be very dark on everything. when it has been on for awhile everything is mostly ok( because i have the brightness andtint turned all the way up) but i am still having a problem when something comes on the screen and it is mostly white the screen goes dark.i.e. the new schiek quatro commercial at the end when the screen is white and it shows the namen and the razor. i cant see the name or anytihng because its in dark writnig and the screen is so dark. also there is a black line across the top of about 1 1/2 incehs where there is no picturee and i can see a blue line and a red line.....anyone with any help would be a lifesaver
  • 1 more comment
  • boulder40 Mar 06, 2008
    its actually from 2000 model VS-60607. And I also dont have a remote with it
  • boulder40 Mar 12, 2008
    there was no sogn of any fluid on anything in the tv
  • wi2049 Nov 09, 2008
    I have to increase the black levels on the pioneer tv to see a picture that is a scene in the dark
  • 116 Answers
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0157" use the audio button to select "video chroma" adjustments, use the video button to select item "68 - AG1", use the adjust button to change the setting to 0, then press the enter button to store the change
Posted on Mar 05, 2008
  • Paul Buscema Mar 06, 2008
    Well, that model is a little older. This is probably not a simple fix. These sets had bad capacitors and also leaking picture tube coolant. If it is a capacitor, it is most likely C2P05 (100@16v). To determine if the picture tube(s) are leaking, unplug the set from your power source, take off the front speaker grill, remove the access panel and, with a flashlight, look VERY carefully for signs of leakage on the printed circuit boards. You may see clear liquid in very small amounts, or a white/green look to the spill drops if it has been there a while.
  • Paul Buscema Mar 12, 2008
    Then the problem is most likely the capacitor mentioned earlier. At this stage, you might need a local Mitsubishi servicer to replace it.
Mitsubishi TV 65 inch rear projection. WS 65809 I went thru the convergence ic chip replacement years ago. Love the TV. My problem now is that the brightness goes from full bright to full dim then...
The old Mitsubishi units had a super capacitor in the logic circuit instead of a backup battery. This capacitor became leaky over time, causing the problem you describe among others. Number one symptom is set has audio and dark or black picture when powered up. As the super cap charges to full voltage, picture comes and goes.
Nov 27, 2014 | Televison & Video
Sony KDF-42WE655. Screen goes dark.
Replace your lamp if you had it more the 3 years.
Nov 08, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Screen flashes white
i sold electronics for sears for years and let me just say that samsung has a great picture and good price but they have a wide spread reputation for having bad mother boards and they know it if you buy one always get a extended waranty you will need it.
Mar 04, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Dark picture problem
there are 2 mirrors did you clean both there is one down in front near the light source when front screen removed lean in and look down there is another smaller mirrorclean it
Jan 02, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62327 Screen is very dim
I tooked the front screen off the TV set. I fallowed the instructions from another wrighter. The Bottom mirror was clouded with dust. I used a cleaner made for cleaning ipods and put it back together with instant success. I had not cleaned it since I got it almost four years ago. I just thought it was getting dim.
As far as the VCR playing black and white it also an easy fix. The Satalite Service man was swapping out my receiver and inadvertaly put the device on componite side of the TV. I put them back on Inpute 1 and 2 and they also work just fine. Thank you for your help.
reading other people porblems I was able to repair it on my own.
Dec 26, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Vs-60705
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility that works on rear-projection TV's should be able to repair your set. I bought the set on Jan 1, 2000. Coming up on 9 years and the set works like new.
Jul 30, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Little white dots on the screen
dirty lens, dirty mirrors, warped light guides, spider webs and mini-UFOs that fly across the inside can cause what you described.
but 6 months is pretty early for a cleaning but possible.
May 16, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Vs-60607 brightness problems
This sounds like it is a problem with the tv. Mitsubishi does have a problem with filter caps in thier regulator circuits. A repair tech will have to fix it.
Mar 06, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from partstore.com.
Dec 28, 2007 | Philips Magnavox 51MP392H Rear Projection...
Please help
If its a rear projection TV. It sounds like the Lamp is shot on the projector, or is going. Look in the back and see if it is lit if it is flickering I would definitely suggest replacing it. If that doesnt repair it then I would ultimately suggest the optical engine which is the projector of the TV
Jan 30, 2007 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
266 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
