ADVENT T9030 after booting notton go back then failure code gb_ui_ support (1199) press any ket to reboot, same comes back, screen blanks after while vga card cure this, two hdd, hdd check one drive found. drive with os failed replace drive found recovery with orignal disc. same failure code
    Genius:
  • 3,587 Answers
Sounds like a blown bios, amigo. you'll need to reinstall or 'flash' the bios
Posted on Mar 04, 2008
UI/NC CABLE FAILURE RESET THE MACHINE CODE IN WORKCENTRE 7675
Your error is either a disconnected cable or a bad cable.
Xerox refers to the Operator Panel as the "UI"or User Interface, and the "NC" as the Network Controller. The cable you probably need to check or replace is 117K37660, coming out of the Operator panel back to the copier.
Sep 12, 2014 | Xerox WorkCentre 7665 Copier
My Advent quantum q200 laptop will not alow me to go onto the recovery menu and also it will not alow me to see other ways to boot it up' what can I do to get to boot up with out using a reboot di
you can reach recovery mode by first shutting off your computer. 2 turn it back on and as soon as you press the power key start tapping f5 constantly and your screen should go into safe mode. you can the put your computer to recover or set it back to an earlier date and time. hope this helps.
Apr 29, 2012 | Computers & Internet
When turned on, i only get the toshiba screen, then the screen goes blank. then i get this message intel (R) boot agent version 9.1.03 copyright (C) 1997 - 2002, intel corporation PXE-E61: Media test...
That will happen if there is a disc in the DVD drive or another usb device that it tries to boot from OR the hdd is not set as first boot device OR the hdd has errors.
Dec 05, 2017 | Toshiba Satellite 1405-S151 Notebook
Advent black screen
This sounds like a bad video driver update.
Restart the machine and repeatedly tap the F8 key. When you see the advanced boot menu appear choose safe mode.
You will see white text on screen that will stop on a system 32 driver, wait a minute and let it boot through.
Next, go do device manager and uninstall the display drivers or roll back the driver to a previous one.
Reboot the machine and it should boot into windows normally. You may have to reinstall the display drivers if they don't reinstall themselves.
Please post back if you need anymore help or advice.
Good luck.
Jun 26, 2010 | Advent Netbook
Rebooting loop on advent laptop
See if it will run in safemode tap F8 as it boots - then choose "safemode" - see if that works If it does:-
  1. Try doing a system restore to before the problem started start> programs> accessories> system tools> system restore > choose a date before the problem started
  2. If that does not work, then try doing a clean boot - details here http://support.microsoft.com/kb/331796 Now if it works when booted normally - you will need to go back into the configuration tool and find out which program is causing the issue - reply here if that's the case, and I can work you through the detail
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 01, 2010 | Computers & Internet
Screen goes blank after afew second on ac inly
Try booting to the Safe Mode (F8 at boot) see if you get any further. Also, does the system complete boot (DO you hear windows sounds?) or is the system just hanging after the Splash screen (You can also try an external monitor and press Fn+F8 to enable the external display) If you can get video externally, then is it likely a LCD or video card failure. If you can't boot to the safe mode and you do not hear the Windows Welcome sound that normally plays at the desktop, then the system is not booting and you have either a hard drive failure and/or an operating system failure.
See if you can boot to the BIOS (F2 at boot), then reload the default settings and reboot.
If you suspect the OS is a problem, boot to the XP CD, then run CHKDSK /R and see if that helps
You can also run system Diagnostics by pressing Fn+the Power button
Dec 21, 2009 | Dell Latitude D800 Notebook
HP Compaq NC6220 won't boot
I'm running into the exact same issue. Were you able to resolve the situation?
Fatima
May 16, 2009 | HP Compaq nc6220 Notebook
Sony VGC-LS35E BLANK SCREEN
Do you mean after windows has booted you have a blank screen?
Boot into windows in safe mode (by pressing F8) during the boot up process.
When booted go into device manager and remove any video drivers under display adapters, if it asks to delete the files as well answer yes.
Reboot into normal mode and let windows find the driver for you.
Apr 19, 2009 | Sony Computers & Internet
ADVENT KC550P Lap Top scren
the pc is standing at command prompt, which means it is unable to find the boot.ini file required to boot into windows
When you say you pressed F8 did you keep pressing it until you got a menu saying Safe Mode,last known good configuration, start in VGA mode etc, if so use last known good configuration and let it reboot.
If still nothing then you will need the windows cd to perform a system repair.
Aug 20, 2008 | Computers & Internet
PC REBOOT OVER AND OVER AGAIN.
YOUR HARDRIVE MAY BE MALFUNCTIONING, IF U HAVE A RECOVERY CD, U MUST GO INTO THE COMPUTER SETUP, WHICH GIVES U THE KEYS TO PRESS WHEN THE COMPUTER COMES ON USUALLYA KEY LIKE F1 OR F8, PRESS THE CORRESPONDING KEY, GO TO THE BOOT MENU AND CHANGE THE BOOT SEQENCE TO BOOT FROM CD DRIVE INSTEAD OF HARDDRIVE FIRST ORDER. RESTART THE SYSTEM AND SEE IF U CAN ACCESS THE HARD DRIVE
Aug 11, 2008 | Dell OptiPlex GX620 PC Desktop
Computers & Internet Logo
63 people viewed this question
Alun Cox
David Payne
David Payne
