Question about Frigidaire FLGB8200DS Top Load Stacked Washer / Dryer
Noise I have just purchased this stackable washer/dryer and I have used it a couple times and it has a loud knocking noise not only when spinning, so its not an uneven load, but it also happens during agitation but you can hear it half agitiation. what I mean is it agitates one way you don't hear it then it comes back the other way you hear a knock. I checked for the shipping block and it has been removed. It is also sitting on a tile floor as this is a top floor laundry room, if that has any effect. We also checked to make sure it is level front to back and side to side.
  • andreldixon Dec 13, 2008
    Water not draining from the tub of my stackable washer/dryer. When the washer is engadged into the rinse/spin cycle, the water does not pump out. Could this be a defective pump?
    Genius:
  • 3,587 Answers
Sounds like there's something inside the tub, can you do a visual inspection and maybe run your fingers around the agitator..stranger things have happened.
Posted on Mar 04, 2008
Just bough a used frigidaire stackable unit model FEX831CS and washer makes extremely loud noise on spin cycle. and dryer takes over 2 hours to dry a regular load of clothes. Please help
Hello uucyc1 - From what you have described it sounds like you either have a problem with the washer tub bearing, belt, motor or trunnion (steel bar that secures the inner basket to the transmission shaft). As far as the dryer, long dry times typically are a result of poor air flow. Make sure that the dryer exhaust vent is completely clear and that the unit is not overloaded. I would suggest contacting an experiencing service technician to determine the precise cause to both units.
Mar 02, 2013 | Frigidaire FEX831CS Top Load Stacked...
I have a frigidaire stackable washer and dryer one solid unit the dryer will sqeek really loud when the drum turns but it sqeeks in the same position every time. but it does sometimes and sometimes it does...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 01, 2011 | Frigidaire Dryers
My kenmore stackable dryer squeaks really loudly. how to stop this it's making me crazy
heatman101
Asker
Jan 23, 2011 | Kenmore Dryers
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Washer makes loud vibrating noise when spinning. GE stackable washer dryer
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion........
Jul 19, 2009 | Washing Machines
Very loud spin cycle
It sounds like the bearings have gone out in the tub. The major cause of this is using powder soap. There is nothing you can do but replace the rear outer tub. This is a costly fix but maybe worth it for a stack unit.
Jun 26, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
heatman101
hgd76
Jun 26, 2009 | Maytag Neptune Washer
My stackable whirlpool washer doesn't spin/work
The most likely cause is the motor coupling , its the plastic and rubber parts between the motor and transmission. Try turnig it with your finger.
Mar 11, 2009 | Whirlpool LTE5243D Top Load Stacked...
Frigidaire FLGB8200DS Top Load Stacked Washer / Dryer Logo
122 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
