Hi
Go to menu-applications-office and then file manager. u will see file memory,mass memory,memory card. now u can select option and then organize to move file from one folder to another.
they have to option to transer your ms word files to your nokia n97
1st you need a bluetoot device then coonect to your pc then if you see the blue tooth just click your item you want to send to your phone right click it then send via blue tooth then they search for devices make sure that your phone bluetoot is open
2nd you need a card reader and take it off your memory card out then put it to your computer then copy your files then go to my computer then you see your memory card then paste it there.. :)
hope it will works on you :)
this is the simpliest way if you dont have a pc suit or even a bluetooth on your pc. just remove the mem.card of your phone.Put it in a card reader, then copy the zeon antivirus file from your pc to your mem.card.After that insert your memory card again to your phone.Then on your phone goto file manager/memory card/and find the antivirus that you have copied..then click it and it will install..hope this helps...
Hi, Most of the mobiles will prompt the user to select the mode of connection when connected to computer such as "Mass storage mode/data transfer mode" and "PC suite/modem mode". If you select the "Mass storage mode/data transfer mode", then only your mobile phone's memory card is connected to your system just like pen drive. so only the pictures present in momory card can be accessed. For transfering pictures from phone memory, try the following methods, 1. Go to your file manager in mobile phone, move the pictures from your phone memory to memory card. 2. Install proper PC suite for your mobile, connect to system in phone mode/modem mode/pc suite mode. Then using the PC suite file manager in your system, oyu can access files stored on to phone memory as well as memory card. 3. Connect a bluetooth dongle to your system, establish a bluetooth connection to your mobile. Threw bluetooth file manager from your system, you can browse the phone memory of your phone. I hope any of the above tips may solve your problem.
I had the same problem,
I guess the memory card just isn't compatible or its to large for your phone. Try taking the mem card to another phone to get back all the data and sync it to your phone.
You don`t need any pc suit. You muse set your phone: Enter in the phone to: menu->setting->connectivity->USB connection mode and here set Mass storage. Now put the usb cable and you can transfer data form memory card to your pc.
