Question about Philco (R) Suitcase CD Shelf System
Record won't turn
I have been reading some of the other posted problems and it sounds like maybe the belt has fallen off causing it to not turn. I was wonder if there is a specific way to open the record player or how to take off the platter to look inside.
  • sruble21 Mar 04, 2008
    The model is a Philco 851.641
  • sruble21 Mar 05, 2008
    Thanks.. now I have found the belt and not sure if it was the cause of my platter not turning. I turned the switch on and the little pole from the motor didn't turn at all. Does this mean the motor has gone bad or it needs to be greased up? The record player was playing music and all of sudden my friend grab the vinyl off the platter and then it stopped. Thanks again!!
There is a white switch that sometimes gets stuck underneath the platter. You have to remove the top screws around the the outside of the case after you open it up. No need to remove any screws in the switch area. After removing the screws pull on the platter post and lift off the wood pressed table. Look for the white plastic switch and move it. This should do the trick if your motor and belt are good.
Posted on Jun 24, 2008
  • 593 Answers
Often the platter just comes straight up and off its spindle. The belt is long and runs to a small pulley off to the side. IF it is a direct drive (not likely) then there is no belt, obviously.
Posted on Mar 04, 2008
  • Steven Wander
    Steven Wander Mar 05, 2008
    Motors rarely go bad, especially a low RPM motor like that. I would look at a fuse or just a wire that has come loose.
My jensen three speed turntable is not spinning my record
If it is a belt driven model it might have fallen off. If you lift up the turntable matt it should show a hole to view the belt. If the belt is good, it could be that a switch is not engaging when the arm moves out to the record, if it is the type that starts when the arm is placed on the record.
Mar 09, 2016 | Jensen Audio Players & Recorders
Electro Brand model number 9801: I played one record, now when I tried to play another the turntable will not rotate. Could the motor have burned out that easily?
Listen carefully with your ear to the turntable when you move the tone arm towards the record. If you can hear the motor running and the turntable is still stationary then the drive belt from motor to turntable has probably fallen off of broken. Lift the turntable, there's normally a metal clip holding the turntable in place, and locate the drive belt.
Jan 19, 2014 | Teac GF-350 CD Shelf System
I have a JD L110 that will not stop the blade from running when I turn the blade off. Then it will throw the belt off before I can turn off the motor.
Sounds like something is loose, maybe stretched belt or loose spring. This will be tough to diagnose with seeing the unit. Can you post pictures of belt drive on unit? Or maybe post a video of unit doing this problem? In the meantime, try turning unit off without disengaging pto, should keep belt from slipping off. Good luck and happy wrenching!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 13, 2013 | John Deere Garden
We just got a crosley radio CR66 model,we cannot get the turntable to activate,it wont turn!It is brand new! so I dont understand whats wrong? we hear a click sound but nothing happens please help ty Bill
remove the rubber plate at the top of the record player,, under that is a metal plate, in that plate is a large "sight hole" look in that as you turn the plate around,, look for the belt that has fallen off the motor shaft and the plate itself,, if you can't locate it, there is a spring clip at the base of the post that holds the metal plate on, remove that , you will see the motor shaft, and the ridge on the underside of the metal plate that the belt has to be on, they sometimes fall off in shipping,
Sep 07, 2011 | Crosley CR248 Turntable
My marantz tt 155 turntable won't turn. is there a turntable lock? or is the only other reason a broken belt? thank you.
Could certainly be a broken belt. Lift record tray and look to see if belt has fallen off or has basically fell apart. Belts can be purchased at Marantz.com. If no belt could be a bad motor. Same website.
Mar 25, 2011 | Marantz Audio Players & Recorders
I accidentally turned off the player while a record was playing. Now when I try to play a record, the needle will hover over the record but the turn table will not turn. Any idea on what the problem is and...
The turntable has to go back to its reset position ( Or Start position ). Turn the platter with your hand while the system is on and see if you can get a light click after some revolutions.If so you have rest the system and should play. Or else lift the rubber Matt and see if the belt is still wrapped round the platter. Rotate the platter while you are doing it and at one point you will see the pulley of the motor and the belt very clearly. If its fallen off put the belt back on.
Mar 08, 2011 | Spectra SB6053 Turntable
After storage my PS5550 does not work. Is there a fuse that may need replacing
The most likely cause of this is a damaged drive belt. Depending upon the type of storage, the belt may be compltely deteriorated. A replacement belt is available for around $8 or so. To confirm this, remove the record platter and examine the area. I would expect to see the belt fallen off of the platter,
Dan
Jul 12, 2010 | Audio Players & Recorders
The record won't turn at all....maybe the motor? speakers work, radio works. needle goes over but goes right back cause record isn't spinning. (just bought it last night, so i really have no idea how to...
check if the platter spins if you manually turn it.
The platter is motor driven either directly (rarely), by a belt or by a rubber idler. The only way to know is to remove the platter or by model # (which is not listed on this post.)
Check the platter and post back with the model/make in the body of your post.
Oct 29, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
May 03, 2008 | Technics SL-1210 Turntable
Record player belt
Scott, the belt wraps around the bottom of the turntable platter, then put the platter back on your turntable, and you'll have to pinch back a section of the belt and wrap around the brass motor spindle. That's pretty much it!
Good luck.
- OPTiC
TWEAK A/V LAB
Apr 13, 2008 | Technics SL-1200MK2 Turntable
Philco (R) Suitcase CD Shelf System Logo
422 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
jason
Morne Olivier
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
