Question about Brother MFC 210C All-In-One InkJet Printer
MFC 210C Ink Problems
Consistantly tells me (all) ink levels low. Then 'shuts off' when perceives ink cartridge is empty... EVEN AFTER ALL CARTRIDGES HAVE BEEN REPLACED AND ARE FULL with Brother ink cartridges.
Very frustrating. Have cleaned, pulled and returned power, jiggled cartridges, pull cartridges and popped them back in... all to no avail.
Any solutions?
=steve
  • stephladder Mar 05, 2008
    Your last solution worked. (Unplugg, wait 10 min., etc.)
    Thanks!
    -Steve
  • lonerg Mar 08, 2008
    when I replace the black cartridge in my MFC 210C the amchine does not recognize it it keeps telling me to install cartridge
  • 832 Answers
Steve,
did you watch the display after replacing the cart?
Very often the machine asks if you have changed the cart and demands an answer (1 for yes).
You can try to do an update of the firmware, too. Go to www.brother.com , choose your country and then your machine. Download a small update tool and run it.
If it aint getting better:
Do unplug from power outlet (even though you have done already) wait 10 Min. leave scanner cover open and take all carts out. Plugin to power again and leave scanner open. Wait uintil machine gives a warning signal. Reinsert carts and close cover: now watch the display and give always the answer YES(1).
Posted on Mar 04, 2008
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
Printer keeps telling me that the yellow cart is empty and I have put a new one in
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
May 03, 2010 | Brother MFC-5440CN All-In-One InkJet...
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
I have a Brother MFC5460CN...I can't find the owners manual and I can't figure out where the ink cartridges are? I need to replace them
I found this on the Web site. You can download the manual for yourself. Just click on the link below. If you find this information helpful, pls rate me.
http://www.retrevo.com/d/ds/progress?doc=9adbcf37695f2981dab6cde6d0fdb2d1
Replacing the ink cartridges B
Your machine is equipped with an ink dot counter. The ink dot counter automatically
monitors the level of ink in each of the 4 cartridges. When the machine detects an ink cartridge is running out of ink, the machine will tell you with a message on the LCD. The LCD will tell you which ink cartridge is low or needs replacing. Be sure to follow the LCD prompts to replace the ink cartridges in the correct order.
Even though the machine tells you that an ink cartridge is empty, there will be a small amount of ink left in the ink cartridge. It is necessary to keep some ink in the ink cartridge to prevent air from drying out and damaging the print head assembly.
a Open the ink cartridge cover. If one or more ink cartridges are empty,
for example Black, the LCD shows Ink Empty Black and Replace Ink.
b Pull the lock release lever down and take out the ink cartridge for the color
shown on the LCD.
C Open the new ink cartridge bag for the color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1). Each color has its own correct position.
Insert the ink cartridge in the direction of the arrow on the label.
f Lift each lock release lever and push it until it clicks, and then close the ink
cartridge cover.
G If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example, Did You Change Blck?) For each
new cartridge you installed, press 1 (Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge you installed is not a brand new one, be
sure to press 2 (No). If you wait until the LCD shows
Note
If the LCD shows No Cartridge after
you install the ink cartridges, check that
the ink cartridges are installed properly.
Pls rate met. Thanks and Good Luck.....
Feb 05, 2010 | Brother MFC-5460CN InkJet Printer
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Bad printing after changing 2 inks also clicking noise not before
shouldn't be the ink. I assume you have an epson as in the picture. my ink refill kit mentions that "epson intellidge chipped cartridges" require an "ink level resetter" to complete the kit. So if you have these cartridges even once refilled the chip tells the printer the cartridge is still empty so you'll need to reset the chip with the ink level resetter.
Aug 20, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Reset ink levels on dell 944
If you refilled the cartridges, you may want to try new Dell branded cartridges.
May 27, 2009 | Dell 944 All-In-One InkJet Printer
Overiding Empty Cartridge error for Dell A10 962
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Nov 15, 2008 | Dell 962 Photo All-In-One InkJet Printer
I would take out both cartridges and put them in again. Realign the printer and the error codes should remove themselves. Try turning the printer off and on before puting the cartridges in again. That may make a difference. You can let your computer know not to tell you when the ink is low too. Let me know how this work for you.
Cynthia Charczenko
Dec 26, 2007 | Dell A940 All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
166 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
