Question about Candy CPCA240FFK Bottom Freezer Refrigerator
Lights out & fridge freezing after switching off and moving it
I have a Candy fridge/freezer. It has worked happily for maybe 2 years. Now the internal light has gone off, the front light that shows it is working has gone off and the fridge freezes its contents. All these faults developed simultaneously after i unplugged and moved it to clean out the drain hole from behind. I unbolted the cooling fins (but hardly noved them)and unclipped the pipe to the drain hole. Once clear, i put all back again.
  • 1 more comment
  • dave20 Mar 09, 2008
    as above, fridge freezing plus ** light
  • thevilla May 07, 2008
    the fridge part of my frigdge/frrezer keeps on freezing.the lights have gone off replaced bulb and still not working. defrosting ice off back wall made no difference as it started freezing again
  • Anonymous May 18, 2008
    Bulb hs gone (and lights on the panel inside the door) and fridge seems stuck on supercool (ie starting to freeze stuff, not super frozen but enough). Wondered if a fuse has blow and the control board/panel isn't working, hence it's stuck on highest value. Struggling to get to any fuses though
I agree that the control board is probably the issue. I noticed that the light inside stopped working. I put a new bulb in but thias didn't work. I then noticed that all the LEDs on the front weren't on either. The compressor seems to be running all the time. If you remove the front of the fridge at the top you can access the control board. I bought one for just under £50. I will let you know if fitting a new one has fixed the problem
Posted on Jun 26, 2008
A servicing expert told me when bulb goes can cause a failure on control board. others confirmed control board failure occurs often and the only other part that goes is the compressor (and thats really expensive to repair!). control boards can be fitted yourself - mine cost about £50.
Posted on Mar 08, 2008
Candy futura cfmf 266a fridge freezer problem
Either the thermostat is set to high or you need to replace the thermostat.adjust it to 1/2 way position position and if temp is to cold and it doesnt want to switch off, it means the thermostat is faulty.
May 21, 2010 | Candy CPCA240FFK Bottom Freezer...
Candy Frostfree Fridge freezer, model CPCA240FFK
1st of all conferm that the compressor is automatically (through Thermostate) going to ON/OFF or not, if it automatically goes OFF, i sugges its OK. and if not its no problum. (Minimum 4 hours rest is Must of a compressor, u can maunally OFF it for daily 4 hours Sleep)
Take Care
Shafky
Jun 17, 2009 | Candy CPCA240FFK Bottom Freezer...
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Freezing frosting fridge
i had the same problem recently with all my fridge food freezing up, this all seemed to start when i discovered the interior bulb blown i replaced it still nothing also noticed warning lights on front out,i could hear the motor going so i knew it was on i removed back cover and found the heater covered in ice it turned out it was the failure of the control board causing these problems had it replaced and working fine now hope this is of help dmb23
Jan 10, 2009 | Candy CPCA240FFK Bottom Freezer...
The fridge part of my fridge freezer keeps freezing everything,
Hello
I have the same problem and have talked to the manufacturer. They said to turn off the appliance for 24 hours then it should be good as new when you switch it back on. Obviously you'll have to find somewhere for your freezer contents. I'm going to try this myself tonight.
Fridge Reboot!
Jan 05, 2009 | Hoover HCA390FFK Bottom Freezer...
Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Oct 14, 2008 | Candy CPCA270FFK Bottom Freezer...
Fridge freezer not reaching operating temperature
maybe its time your fridge to go to the service center. 5 years is a long time yaknow. have them check for the freon as it might have runned out.
Jan 14, 2008 | Candy CPCA240FFK Bottom Freezer...
i have candy fridge freezer which the thermostat is on high setting but not cold as it should be. There is build up of ice around thermostat at the back of fridge inside. What is needed to repair?. Any ideas? Cheers!
Nov 02, 2007 | Candy CPCA240FFK Bottom Freezer...
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
251 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
