Question about Brother IntelliFAX 560 Plain Paper Fax
I don't have my manual and can't remember how to use the second function part ofthe keys :copy/help and function/setup.
am trying to use the copy key and all it will do is print the help list.
  • 2 more comments
  • Anonymous Apr 06, 2008
    Cannot make copy
  • Anonymous May 07, 2008
    Need to change fax #
  • Anonymous Dec 18, 2008
    i lost the manual and can't hook it up
  • jhoptr Feb 18, 2009
    Can't seem to be able to make a copy
How do you receive a fax
Posted on Mar 23, 2008
Several recepients cant read my fax, very feint. Is it a fault with my fax?
Try making a copy on your machine and see what the copy looks like.
What are you sending,??? if its a second carbon copy of something...remember what you see is what you get...if the original is poor quality the receiver will get poor quality. You can darken the image slightly...refer to your operators manual.
Jun 16, 2010 | Samsung SF-560 Plain Paper Laser Fax
We are getting Error CODE 021 on our fax machine Panafax UF-560 and can't find the owners manual to fix it...can you help?
Error code 021 indicates a bad fuser but in some cases, the error can be reset. To attempt a reset, do the following:
  1. Remove the toner cartridge and close door back up.
  2. Power down the fax (switch is on the back side lower left) for 5-10 seconds.
  3. Power on the fax and see if the 021 code is gone.
  4. Re-insert toner cartridge
If this doesn't work, there's one other thing to try prior to calling a technician.
1. Push the function button
2. Push 7 on the key pad
3. Push Monitor button 4 times (it will only beep at you)
4. Push * on key pad
You should now see the service menu option
5. Push 7 on the key pad
6. Push "Set" button
7. Push down arrow button once
You should now see the fuser reset option
8. Push "Set" button
You will be prompted for 1 for Yes 2 for no
9. Push 1 on key pad.
You should receive confirmation that the reset is *COMPLETE*
10. Push Stop button until back to the main screen
11. Power down the fax
12. Wait 5-10 seconds.
13. Power on the fax
If this doesn't work, a service call will be needed to replace the fuser. I do hope this fixes your problem.
(reset information courtesy of Eliot at
Nov 12, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
How to clear memory on Panafax UF-560 ?
monitor key slowly 4 times
scroll down to SHIPMENT SET
wait for the machine to initialize.... 3 mins.
Oct 09, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
A manual for fax 560
Get it from ManualsOnline at:
Right click The blue "Get This Manual" button anda save the file to you computer.
For a limited time, you can also find a copy here:
Jun 27, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Looking for printable manual for 560 brother fax machine
Go To this link
May 31, 2009 | Brother IntelliFAX 560 Plain Paper Fax
FAX 560 Brothers displays message "Memory Full"
Do you have faxes in memory? You may need to either erase faxes in memory or print them out.
Printing a Fax in Memory
If you have Fax Storage ON for remote retrieval, you can still print a fax in the
memory when you are at your machine:
1 Press Function/Set, 8, 4.
2 Press Start.
3 Press Stop.
(See Turning On Fax Storage, page R-2.)
Apr 04, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Help when i try to fax using my brothers 560, the number dials, the machine sounds like it's faxing, but the disply says telphone. how can i correctthis
Do you pick up the hand set when you are dialing, If you do the display will read telephone. When you want to send a fax put the paper in the document feeder. Dial the # press the start key or put the documents in the document feeder press the hook button to here the dial tone, dial the number what for the tones pres the start key. hope this helps
Jan 29, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Print Size Changes
This maybe down to the other persons fax machine if your copy is coming out perfect try sending it to a different fax number to see what happens.
If the same thing happens press the menu key and you are looking for a heading call setup or machine settings within one of those will be TTI settings and make sure that reduction send is not on.
Hope this helps sorry a little vague but have manual at work
Thanks J
Nov 22, 2007 | Brother IntelliFAX 560 Plain Paper Fax
Brother IntelliFAX 560 Plain Paper Fax Logo
277 people viewed this question
James Cagle
James Cagle
Jim Keysor
