Colours on the tv have become distorted particularly black which now has a reddish orange smeared appearance. Problem seems to get worse as the day goes on. Tv is only 7 months old.
  • 2,326 Answers
The TV is getting magnetize, may be from speakers nearby or any other source. The degaussing circuitry is not functional.
If the TV is only 7 months old, I would say still under manufacturers warranty.
Call the place where you bought it and ask them for an authorize repair center to fix it.
Posted on Mar 04, 2008
Olympus u820 image distortions colour and form
One answer time for a new camera the cost to repair is about the same as new.
Mar 15, 2017 | Olympus Stylus Stylus 820 µ Digital 820...
I'm having a problem with the color green being distorted on my TV. Is this a color tube issue, bulb issue, lamp issue?
This is a picture tube type TV. No lamp.
You don't describe the distortion.
A colour green picture that is twisted and shifted away from the other colours is a convergence problem. see Projection TV Convergence on this site.
If the green is smeared, out of focus, larger than the other colours like a halo around objects, things like that, it is the green picture tube. Sony has discontinued most of the picture tubes so you may not be able to get this fixed.
Mar 31, 2010 | Sony KP-46WT520 46" Rear Projection...
Red/orange color
If your set is led or lcd your Tcon board is getting to the end of its life, its the lowest cost board in a TV
Dec 01, 2017 | JVC LT-32P679 32 in. LCD TV
The colour on my TV is a reddish colour. Have tried the colour adjustment. Skin colours in particular.
simple. easy. you have 3 screen adjustments. red green blue. turn color all the way down. you should then get just a black and white picture, but in your case, it will still be reddish. behind the speaker grill is an access panel for screen adjustment. remove speaker grill. remove access panel. you will see a block assembly roughly 6 inches square with 6 knobs on it. 3 are for screen, 3 are for focus. adjust until you have a black and white picture. then go into menu and turn your color back up. enjoy!
Nov 14, 2009 | Televison & Video
Samsung LE26R7 4BD, approx 4 years old, colour distortions
Check all of your cables on the back of the tv and your sources such as Cable,Sat box and DVD palyer to make sure they are fully inserted into the input and output connectors. Some times Component cables will work loose and you end up with a missing color. Temprature changes can affect intermittant connections. If that does work then you have a bad Main bd.
Jul 02, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
SAMSUNG PROBLEMS - Red and Green Shading All Over Screen
adjust vscan  vs & va voltages on power supply, if not that drive pcb's are bad
Jun 05, 2009 | Samsung LN-S4051D 40 in. LCD Television
XBR 4 vertical black band, ghosting/smearing, getting worse.
Hi, I have a similar issue which is progressively getting worse. My TV is on a sliding mount, and interestingly enough, sometimes I can "jilt" it by hitting it and it clears. This seems to me to be a connector problem, where heat (thermal expansions, electrical resistances) can introduce degrading signal. Now if I could find a manual on how to take this damn thing apart.......Certainly does't solve the warranty issue, but at least gives a reason for one to kick their TV.
Mar 12, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
After a household power blips during bad weather, we have horizontal lines ....
Unfortunately there isn't any way to repair your tv as the magnet has distorted the tube that is in the tv and with CRT becoming obsolete the repair is likely to be very costly so probably your chaepest option is to buy a new tv .
Mar 13, 2008 | Televison & Video
Try # 2... Green Fog
The green gun in your picture tube is set a little too high. If you are experienced in removing the back cover of TV's,etc., you may try to find the drive and/or bias controls either on the circuit board that plugs on to the neck of the picture tube or mounted on the main circuit board of your TV. These controls are usually labeled. If you can find them, locate the green bias or drive control and back it down a little while watching the picture through a mirror. A slight adjustment may correct your problem.tJIS IS CALLED GRAY SCALE ADJUSTMENT. BE CAREFUL THERE ARE SOME HIGH VOLTAGE CIRCUITS NEARBY. WORK WITH ONE HAND AND USE AN INSULATED TOOL TO MAKE ADJUSTMENTS I hope this may help you.AGAIN BE CAREFUL!! Stargazer
Feb 26, 2007 | Toshiba 32HFX71 32" TV
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
