Question about GE JE1590 Convection / Microwave Oven
Ge spacemaker the inside light on my microwave oven stoped working where the hell is it located where is inside light on the ge je1590 series?
  • dak1062 Mar 07, 2008
    After reading the solution, I decided the light was too much trouble for what it is worth.
  • oscar fillpot Sep 24, 2008
    Do you have to take case off or what to replace the lamp bulb
  • 552 Answers
Here is info from another person having that problem on fixya.
I had to go down to an appliance parts shop in PHX to get the lamp after I had taken the microwave out of the corner cabinet and disassembled it. Found the light bulb toward the right front top corner after taking the frame all apart. It was a pain but it's done !! BTW, I'm a female licensed electrician and GE told me over the phone that I would have to call a service tech to come replace the lamp (about $200). I searched the websites for the part number to get the lamp (it wasn't printed on the lampbase), searched for local appliance part stores and found the part number (WB36X10131) to pick it up. The "cavity" lamp cost me $8.65 then the cost of the gas (about 40 miles) to get it but my micro was back up and running before Thanksgiving dinner --just in time to make Lean Cuisine !!! HAHA Thanks for your reply Guru !! Have a great weekend !! Julie
Posted on Mar 04, 2008
My GE Spacemaker Microwave Oven appears to be working normally (light comes on, table turns, sounds normal), but it doesn't cook anything. Might there be an easy fix to this problem?
Unscrew the screws holding the exterior shell to the unit, then lift off. Now unplug the magnetron and take it in the shop to match up the #s so you can get an exact replacement. Now install the new part and you should be re-heating left overs in no time. Make sure you discharge the capacitor before poking around inside or you will shock the hell out of yourself. Unless your sadistic and like that sort of pain, then forget about the last suggestion.
Nov 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the light that is inside the GE Spacemaker microwave?
with cord unplugged you can remove the main control panel and access to it
Aug 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have GE Spacemaker made in 7/1983, The light bulb has burned out. The light is located inside the oven. question I have looked and can't find it to replace it. can you tell me where it is located?
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
EVERYTHING IS WORKING BUT THIER IS NO HEAT
This is either the magnatron fuse or the magnatron itself has burnt out!
check fuse inside screw panal
Please rate this answer!
Jan 24, 2009 | GE JE1590 Convection / Microwave Oven
Ge spacemaker runs but wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jan 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker xl microwave oven JVM1440 Two weeks ago after I press 6-express cook stopped and all the lights and clock went blank. In a 10-15 minutes it came back on and the clock would have to be...
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the
left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave - No lights, No fan, all else works great!
sounds like you have a bad control board.. part# WB27X801 this is located behind the touch pad..
Apr 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker
remove the front vent cover above the door - light is inside
Jan 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JE1590 Convection / Microwave Oven Logo
110 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
