Question about E-Machines Athlon XP 2200+ (rb-t2200-c67)
Need wiring diagram for emachines t2200 motherboard
I need a wiring diagram showing the power hookups for an e machines t2200 the previous owner pulled them off without labeling them and we cant figure out where they go
  • chikid68 Mar 05, 2008
    this is the right board and manual . Thank you very much
  • 35 Answers
This is most likely the motherboard you are using. If it is, you can find a manual for it here http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=62&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
Posted on Mar 05, 2008
I NEED TO KNOW HOW TO CONNECT THE POWER SUPPLY FOR AN EMACHINES T1120 COMPUTER. CANNOT FIND A SCHEMATICS DIAGRAM ANYWHERE.
After reading an article about Emachines awhile back, I found out the reason you can't find the schematic- it isn't available, as some motherboards are made specifically for Emachines and therefore not distributed, as they might normally be, but again, others are, but you have to identify them and go through another source to get them- Emachines, appartantly, will not supply them. All is not lost, however...all motherboards have, basically, the same hookups and connectors for the power supplies, hard drives, etc.- they are standard. I found a web blog that explains the power switch, reset, and power led, which will help. Here it is: http://www.computing.net/answers/hardware/emachine-power-sitch-wiring/56545.html
This site will explain about the 24 pin connector from the power supply
http://www.tomshardware.com/forum/53750-7-installation-manual-rs480m-w3400-emachine-motherboard
If you google "motherboard wiring" you will find sites that have illustrations of the motherboard, and explain which connectors go to which sockets, and how to identify them.
With a little patience and determination, you should be able to hook everything up from the various blogs on the net. Hope this helps.
Apr 17, 2010 | E-Machines eMachines Desktop PC
Emachine t2824 board diagram
Here is the diagram that shows you how to hook up the wires:
http://www.fixya.com/uploads/images/284ECAC.png
If you still have no video then reseat the memory one stick at a time in one slot at a time.
If you still have no video then reseat the cpu into its slot.
If still no luck try a different stick of RAM by trying it one slot a time.
Last step, unhook the power connectors from your device so the only power connectors that are connected are the power to the motherboard and the p4 connector to the motheboard. Also make sure your power supply is set to 115v. Its the red switch on the back of the power supply.
If none of this works, then the motherboard is bad. Hope this information helps.
Ben
May 24, 2009 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Need wiring diagram for eMachine 20030812 motherboard!!!
You should be able to see the words/letters that go with the jumpers on the motherboard itself. look around the jumper settings area for power, pwr etc. and match them up with your jumpers which should have what the go to on them.
Apr 10, 2009 | E-Machines eMachines Refurbished EMA...
A power diagram for restoring power for a emachine
Hi there if you look real closley at the wires they are labled such as (pwr)led (reset) (hdd led )
(remote switch this the power for the computer) ect ect now look real closley and you will see the same markings on the edge of the board by each pin that they go to.. or you can also contact e-machines tech support and they will be able to help you out more if needed
best regards mike
Mar 17, 2009 | E-Machines eMachines Desktop PC
Hard Drive Plugs and Wires
Can you post a photograph to assist you better???
Jun 17, 2008 | E-Machines Bestec ATX-300-12E Rev. D 300w...
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
Emachines 220 motherboard IMPERIAL_GV 20030812 driver
i need to download on board driver of imperial_GV 20030812
Mar 25, 2008 | Computers & Internet
Disconnected wires
If you feel comfortable working inside the computer, after taking electrostatic precautions and ensuring the power is off and disconnected, look for a group of colored wires which plug on to a set of pins near one corner of your motherboard. The power wires should be marked "PWR" (or something similar) on the end of the wire, and the appropriate place for it on the motherboard should have the same marking.
If in doubt, take it back to who/where you got if from, and ask them to do it for you, or give us the eMachines model number and we can give more specific info on how to proceed.
Safety first. If you're the slightest bit unsure about what you're doing...DON'T DO IT!!!
Dec 30, 2007 | E-Machines Athlon XP 2200+ (rb-t2200-c67)
LOST POWER ON MY COMPUTER.
You can place your hard drive into an External Hard Drive Case and transfer your files on another system (this would be cheaper than having a repair shop do a ‘data-transfer’).
Nov 10, 2007 | E-Machines T2200 PC Desktop
E-Machines Athlon XP 2200+ (rb-t2200-c67) Logo
2,904 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
