Question about Dell E172FP 17" LCD Flat Panel Monitor
SCREEN BLANKS WITH POWER LIT GREEN
DELL 17" EP172FPb LCD monitor: The power button remains lit green while the screen blanks off. Even when accessing the menu, the screen will blank out. Obviously a problem with the display circuitry itself and not a video adapter problem.
  • barelyinsane Mar 06, 2008
    All caps look good but I did see what looks like dielectric on the underside of the pcb at transformer T753. I am going to try replacing that one as it is the only physical discrepency I could find. Thanks for the help.
Look for bulged or leaking capacitors on the power supply board. If you can solder, you should be able to replace them with the same type and rating and that may just solve the problem. I've had luck with a couple of dozen monitors so far.
Posted on Mar 04, 2008
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Screen is blank. Green LED power light is
Might be your graphics card, try swapping it out for a new one and see if that works
Oct 09, 2009 | Dell E173FPb 17" TFT LCD Monitor
Dell 1702FP 17" Blank Screen Problem
Try it on another computer, if it works the video card moght be dead.
Jul 11, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Monitor L17AMTN flashes WinXP desktop, then blanks.
dmellman, Before you open it up, try this! With fully booted pc and WIN DESKTOP screen up, reconnect the L17AMTN . Have a bright flashlight handy so that when the lcd screen flashes on for 1 second and then goes dark, you will want to check to see if the desktop remains on the screen even though you think it went away. Shine the light 1-2 inches from screen at different angles. Has the desk top completely disappeared or is it still being displayed? Do you know about Cold-Cathode-Fluorescent tubes and their Inverter type power supply? I assume that this unit also has a "lay on floor black box switch-mode-power-supply" that is supposed to supply raw 12v-14v dc to the monitor? This symptom is typical of lcd monitor power supply failure, and or inverter board failure. Not to mention the fact that the CCFT's could be a bit tired from use. YOUTUBE has some videos on taking apart lcd monitors. also do search on web for "bad caps on lcd boards" or "bad caps in lcd monitors". I should think that this Tatung might suffer from swollen cap-itis. get back to me with results of your investigation. Im louie12fix on fixya or lmistyrel@aol.com just nrth of Windy City
Apr 17, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Monitor screens blanks a few seconds after I switch on computer
Took the cable connecting the monitor to the computer and reversed it, this seems to have worked!
Dec 21, 2008 | Sony SDM-S74 17" LCD Monitor
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Black screen
Try pressing the 3rd button, as it toggles the Analog or Digital inputs...
Oct 05, 2006 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell E172FP 17" LCD Flat Panel Monitor Logo
189 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
