Question about Kitchen Ranges
Breadman Ultimate Plus pan won't stay put.
Breadman Ultimate Plus pan keeps jumping up and causes paddle to stop. What is the best way to deal with keeping this in.
Instructions just say about bending out clips this doesn't seem to work very well
  • 1 more comment
  • chris_tann Apr 27, 2008
    I have the same problem as described. I think it is due to gunk accumulating underneath the pan (i tha actual bread machine itself), which is stopping the pan from locking down firmly. If I clean it out (using a screwdriver to scrape off the gunk), it works fine for a few months, and then starts "jumping" again.
    Right now it i running, with the lid open, and a spatula jammed in beside the pan to stop it jumping. Dough cycle only!
  • Dawgpaintbal Jan 22, 2009
    MIne just started doing it I contacted the mfg, and they said to look at the pan. It appears that the edges of the pan are bent downward, I bent them back up and it appears to be working better.
  • Anonymous Mar 28, 2009
    pan jumps off the bottom socket and paddle stops turning. Can't be gunk or wear on the paddle as this is the first bread I make with this machine... I'll try bending the sides or maybe jamming a kitchen utensil across to keep it down.
  • 552 Answers
You may need a new paddle, because of wear and tear.
Here is a link ahere you may be able to purchase.
http://www.nextag.com/breadman-tr2200c/search-html
Posted on Mar 04, 2008
Piece that connects to motor and then paddle fell out
Yes, the C-clip holds the shaft for the paddle in place. I think the only relevant replacement part is the entire pan. Expensive!
Dave Kristol
Mar 23, 2017 | Breadman TR2500BC Bread Maker
My TR4000 machine is leaking liquids. The washers under the paddle are loose. I would like to purchase a new insert for my machine. Is this possible?
It is difficult to find such small parts or even find them. I recommend you just replace what is called the pan assembly which is the pan and parts under the pan, washers, pins, etc. already assembled for you. You just won't have the paddle so be sure to keep yours until your new pan assembly arrives..here is the site you can contact to order your parts. Best Wishes,
http://www.breadman.com/t-customer-care.aspx
Dec 16, 2010 | Breadman TR4000 Ultimate Dream Bread Maker
NY Breadman Ultimate TR2200C stopped working. The "gear shaft" on the bottom of the machine no longer turns. Any suggestions?
Hi, Take the pan and paddle out of the machine and see if you can turn the paddle freely by hand. If no, then the sealed bearing has failed and you will probably need a new bread pan. If it turns freely then it could be the belt is loose or has fallen off. Belts and motor are located in base of the machine. Unplug machine before working on this part. Hank
Oct 31, 2010 | Breadman TR2200C Ultimate Bread Maker
The kneeding paddle is no longer smooth.where can
If the paddle is sticking it could be the sealed bearing on the bottom of the pan is sticking. Either that or the belt is loose and not allowing the paddle to spin freely.
Hank
Feb 08, 2010 | Breadman TR2200C Ultimate Bread Maker
It seems the motor on my Breadman Ultimate 2200C has burned out.
If the motor shaft is not spinning with the bread pan out of the machine it could be the belt has fallen off the pulley, or has snapped. The belt and pulley are inside the base of the machine. Hank
Jan 21, 2010 | Breadman TR2200C Ultimate Bread Maker
My Breadman bread maker is broken. The pan jumps
It is likely that, due to a poor design the contact between the paddle traction and the machine is worn out.. Check it and you will see that the bare metal is shiny there in the two bumps in the rotating plate in the machine.
I used a dremel-like rotary tool to grind the contacting part so that the contact between the machine and the paddle traction is orthogonal.
Worked fine for me.
Regards
Nov 16, 2009 | Breadman TR2200C Ultimate Bread Maker
I,ve been looking for apaddle for my breeadman ultimate plus model TR 2500BC since over a year.The solution that I tried here doesnt work since that internet site has stopped their activities Herman
Try ebay...
http://cgi.ebay.com/Breadman-Bread-Machine-Paddle-Blade-TR2500BC-Ultimate_W0QQitemZ390094347444QQcmdZViewItemQQptZSmall_Kitchen_Appliances_US?hash=item5ad36f5cb4
Hank...
(if link does not work go to ebay ..bread machine paddles and hunt around).
Oct 13, 2009 | Breadman TR2200C Ultimate Bread Maker
I am also in need of a pan for my breadman 2200C.
If I cant get my breadman ultimate tr2200 fixed, I can ship you my breadpan. I guess that would be better than throwing it out. It is like new.
Jul 20, 2009 | Breadman TR2200C Ultimate Bread Maker
Kitchen Ranges Logo
238 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
