Question about Netopia (3347NWG-VGX) Wireless Router (3347NWGVGX)
Netopia losses connection to internet and to server and vp phones
I am a small business using a file server with Windows Business Server 2003. My internet provider (AT&T) recently replaced my old Cayman router with a Netopia 3347-02. Since then we have had nothing but problems. My tech support people tried unsuccessfully to change the ip address of the Netopia router to the ip address of the old cayman router, but each time they tried, the router would freeze and would require a hard boot (back to the factory settings) to restart it. AT&T finally convinced my IT people that the ip address could not be changed in the router and so we changed the ip address in the server and most of my software. For the most part we are up and running, but when we plug in my Toshiba VP phones, the internet goes down within about 5 minutes and can only be restarted by unplugging the vp phones and doing a soft re-boot on the router. Toshiba says their VP phones do not require an ip address to be programmed into the phones, so apparently that is not the problem. Also, about twice a week all the desktop computers lose connection to the internet and/or the file server. If we lose connection to the internet and file server at the same time, we can do a soft reboot of the router and get restarted, but shortly thereafter, we lose connection to just the file server and have to reboot it. I have had 4 different tech people from 3 different companies try to diagnoise my problems and every one of them have told me that this Netopia router is not designed for a business setting. AT&T does not agree. Can you help me?
  • Carrie Smith Mar 12, 2008
    Thank you for your help. My tech was very doubtful abou the DHCP conflict, but it turns out you were right. He resolved the DHCP conflict and now we can plug the phones in without it taking down the internet, however, the phones still do not operate and the display screen says "searching for IPU". They are Toshiba IP Enterprise phones - model IP2010-SD. Both our static IP address and the address of our router have changed since the phones last worked. Do you have any additional suggestions?
The Netopia Is a business-class router. Not clear from you question are you running Small Business Server or Windows Server 2003? If its the former, it has a wizard that will configure your LAN & the Netopia.
You can configure the Local IPs on the Netopia in the DHCP settings in expert mode.
The VP (VOIP?) phones are acting as a DHCP server & re-configure the network to their defaults.
Any 1/2 decent IT person (witth some real qualifications) could figure straiten this out...beware of "Techs"
Posted on Mar 05, 2008
You can change the IP of the router via the GI going in through expert mode and configeration. You can also telnet in, then enter the keyword "magic" then configure. You should get top>>. type "view" and you can step through all the setting, To change a setting step down through the tree by "keyword name"<CR>. until you get to correct keyword level, then to switch an option on/off "set on" or off or "set some-value", then save, then quit or top tio get back to top level of config tree. Known problem is that the target SNR for the down stream direction is set to zero [type in dmt ds tsnr to display this]. Looks like this modum is poorly implimented as it fails to down the speed if SNR drops below 6dB, I replaced it foe D-link DSL-3640B due to these performance problems. The 3640B gets hot but it keeps the SNR above 4 dB from 6500 kbps down to 4000kbps at night and back up next day. (dja.)
Posted on Sep 01, 2009
Why does it say communication error when i try to activate microsoft office 2007
This issue may occur if you configure your Internet connection to use a proxy server that requires authentication. In some situations, the Activation Wizard can not connect through the proxy server to an internal Microsoft server and show error message.
Alternatively, this issue may occur if your firewall software is blocking the attempt to connect to the server through your Internet connection.
To resolve this issue configure the firewall software to let the Activation Wizard connect to the Microsoft server or restart the computer in Windows Safe Mode With Networking, and then try to activate the software.
May 25, 2014 | Microsoft Office Word 2003 for PC
Hi , We are having 2 windows servers with identical configuration, and also we are using the windows 2003 with vendor application, We installed 8 GB of RAM in both server , But I could only 4 GB amount...
To reply your query in short. If you have any of the following versions of server it would support the maximum RAM upto 4 GB.
Windows Server 2003 R2 Standard Edition
Windows Server 2003, Standard Edition SP1
Windows Server 2003, Standard Edition SP2
Windows Storage Server 2003
Windows Small Business Server 2003
If you are using : Windows Server 2003, Web Edition
It will support only 2 GB of RAM
For your information to get a complete information about Memory Limits for Windows Releases. Please visit the following site:
If you find it useful please do not forget to rate this solution.
Jul 14, 2010 | Microsoft Windows Server 2003 Enterprise...
I have an Ml 110 G5 Server, But i could not find the VGA driver for the Win Xp , kindly assist thanks Justin
Hi, I m really sorry to say that but you have a Server Product and its built to run Windows Server Series on it (or Linux / Novell Netware).
This is the list of compatible Server list
Microsoft Windows Server 2003 Microsoft Windows Server 2003 for 64-bit Extended Systems Microsoft Windows Server 2008 Essential Business Microsoft Windows Server 2008 Foundation Edition Microsoft Windows Server 2008 R2 Microsoft Windows Server 2008 Small Business Microsoft Windows Server 2008 W32 Microsoft Windows Server 2008 x64 Novell NetWare 6.5 Red Hat Enterprise Linux 4 (AMD64/EM64T) Red Hat Enterprise Linux 4 (x86) Red Hat Enterprise Linux 5 Server (x86) Red Hat Enterprise Linux 5 Server (x86-64) SUSE Linux Enterprise Server 10 (AMD64/EM64T) SUSE Linux Enterprise Server 10 (x86) SUSE Linux Enterprise Server 9 (AMD64/EM64T) SUSE Linux Enterprise Server 9 (x86)
Here is the link for Drivers
Try to use the Driver for Windows 2003.
It has a Matrox VGA as I know. If you know which Matrox series you have, then Browse here for the Drives: Matrox Graphics Support. Make sure that you choose the Exact Driver software which suites the System.
Note: Not every product has the Driver Software for Windows XP.
Please rate the answer! Thanks for contacting Fixya!
Jun 19, 2010 | HP Compaq ProLiant ML110 G4 Server
Hi My server has 8 memory slots but only 4 seem to be working. How can I make all of them work
It depends on the version of Server OS you have. If you already have 4 GB of memory installed and you're using Small Business Server 2003 or another 32-bit Server OS, then that is all the memory you'll be able to use. In order to use the other slots, you'll need to upgrade to a 64-bit OS. (Full Windows Server 2003 64 bit or later).
Mar 10, 2010 | Computers & Internet
Can't install Internet Explore to Windows Server 2003 SBS
u may have tried with xp or vista internet explorer version, thats not suported in server.
click here to get the server internet explorer version.
Jan 26, 2010 | Microsoft Windows Small Business Server...
I am trying to download PCAnywhere 12.0 to windows 7 and it tells me they are not compatible
That is correct Symantec list supported operating systems and Windows 7 is not compatible..
System RequirementsWindows 2000 Professional/Server/Advanced Server
Windows XP Home/Professional (32-bit and 64-bit)
Windows 2003 Server Standard/Enterprise (32-bit and 64-bit)
Windows Vista Ultimate/Business/Enterprise/Home Premium/Home Basic (32-bit and 64-bit)
Windows 2008 Server
Internet Explorer 6.0 or later
Nov 10, 2009 | Symantec pcAnywhere 12.0 Host & Remote...
Cannot login to configure Belkin SMB KVM-over-IP swith
This happened to me until I installed the activeX control. Were you prompted for that, and did it install successfully?
After the activeX installed, did it also prompt you to install the secure certificate to access the site without IE prompting about invalid certificates?
Since you've tried multiple machines, I doubt security settings on IE are causing the problem. But my switch did these two actions before I was able to login successfully.
Jan 30, 2009 | Computers & Internet
Sync my contacts and calendar from outlook to iphone
You are on the right track.
You need to install the SBS 2003 SP2 package.
It contains Windows Server 2003 SP2 and Exchange 2003 SP2 along with other important updates. (It is a big download.)
Install all of the updates staring with Windows Server SP2.
Once you complete the install of Exchange SP2 your iPhone should sync.
FYI: If you use Remote Web Workplace you will need to forward TCP port 4125 on your firewall to your SBS server after this update or RWW won't work properly.
I hope this helps.
Oct 14, 2008 | Apple iPhone Smartphone
System State not successfully
This is common in the following OS.
• Microsoft Windows Server 2003, Web Edition • Microsoft Windows Server 2003, Standard Edition (32-bit x86) • Microsoft Windows Server 2003, Enterprise Edition (32-bit x86) • Microsoft Windows Server 2003, Enterprise x64 Edition • Microsoft Windows Small Business Server 2003 Premium Edition
This problem occurs when the following conditions are true: • You back up data from a volume that contains a Microsoft SQL Server database. • The recovery model of the SQL Server database is configured to use an option that is different from Simple.
Submit a request here to get a hotfix from Microsoft ( Its free and no product key will be asked )
Feb 18, 2008 | Microsoft Windows Server Standard 2003 for...
Netopia (3347NWG-VGX) Wireless Router (3347NWGVGX) Logo
578 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
