Question about Canon imageRUNNER 4570 Copier
Canon ImageRunner 4570 gives me an error code:E000001-0010
The last time I got this code it was just a matter of properly installing the toner. I have tried that this time but there has been no change.
  • Anonymous Sep 10, 2008
    i have the same problem with the 5070 printer... is the error code the same thing?
  • Anonymous Mar 22, 2014
    my canon machine not work properly.this machine shows error code E000001 how repaire canon machine
  • Canon Expert
  • 1,326 Answers
A E 000 code is a fuser ass'y problem. It will need to be rest in service mode...
Posted on Mar 05, 2008
  • Canon Expert
  • 270 Answers
If after resetting the error and you still get the error code than the fixing film for the IR-4570 will have to be replaced and the error will have to again be reset. The part that is supposed to be getting hot is bad and only that part will need to be replaced.
For the IR-5070, the error code is that the heater is not getting hot. If the error has a 0000 sub code then the thermistors may need to be replaced or the DC Controller. Most likely the heater itself is not bad because thay should last the life of the copier. Try doing an error reset by going into service mode. Additioan function key, 2&8 at the same time and then Additional function key. Slect copier, then function, clear, err. If it goes back into the error the above items may need to be replaced. Good Luck. 0010 sub code is that the copier has been turned off and on without restting the error.
Posted on Oct 17, 2008
Error E000024-0001
the E024-0001 is error code related to toner station sensor. It reports this error if sensor cant read the toner level.
As service work, I would say to reconnect the connectros on toner holder unit and connector on toner/developing unit + clean the connectors with antistatic brush because if the toner get's to connector it can cause troubles.
Also try to reinstall the toner tube and turn off and on.
Hope that helps!
Sep 16, 2011 | Canon imageRUNNER 4570 Copier
Canon copier 4570 error code e000007-0000
canon ir 4570 error solution for Code E000007-0000
Nov 25, 2010 | Canon ImageRUNNER 3570 Copier/Printer
How to solve the matter erased
do you mean that some pice of copy dosnt have "baked toner"?
If yes replace fixing film.
Aug 04, 2010 | Canon imageRUNNER 4570 Copier
Canon Image Runner 4570 Error Code Display E000019-0000 what this parbalm how can u salo this parbalm
E000019 means the waste toner is full. It needs to be emptied out. It is behind the front cover of the copier. There are two screws that hold it in place. Open the toner door and there is one screw there set into the plastic. The other one is on the top left coner of the cover, that may be out? Slide the cover to the left and the waste toner bottle is right there, milky white bottle. Pour it out carefully. Reinstall and turn the main power switch off then on and you are done
Jun 10, 2010 | Canon imageRUNNER 4570 Copier
What this parbalm how can u salo this parbalm
Error code E000019-0000 is a waste toner full error, so to get rid of this error you remove the waste toner bottle which is located left rear side of the machine and dispose the waste toner and dont forget to clean the neck of the bottle because the waste toner might obstract the toner sensor passege and then switch off then on and you are up and running.
Below is your support page to get a manual.
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2275&modelid=918
Where is the waste toner container located and how do I replace it on the Canon 4570 imagerunner copier?
Remove the two screws that hold the front cover on. The waist toner is below the toner container.
May 18, 2010 | Canon imageRUNNER 4570 Copier
How do i replace the waste toner container on a Canon Imagerunner 4570?
The waste toner bottle is hidden behind the front cover of the machine. Just under where you fit the toner cartridge.
If you are competant with a screwdriver, remove this cover and you will find the Waste container. The screws for the cover are hidden behind a rubber bung.
Feb 02, 2010 | Canon imageRUNNER 4570 Copier
Image runner 4570
it might just be a power spike in which case your machine just shot an error while it protected itself...
try the following...
press additional functions
press 2 and 8 at the same time
press code error
press copier
press function
press clear
press error
press ok
press reset
if that doesn't work then call a tech... it might be very serious...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 21, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Canon 4570 E00000
You need to reset the code by clearing the error memory phone me on 07764303923 i am in england and will tell you how to do this
May 06, 2008 | Canon imageRUNNER 4570 Copier
Canon imageRUNNER 4570 Copier Logo
5,211 people viewed this question
old marine
old marine
