Question about Maytag Neptune MAH6700A Front Load Washer
Maytag neptune mah8700 a
Unit in wash mode goes down to 7 min and wont go any farther already installed new front board 4-5 mo agoand its doing again also in spin it shakes badley and walks
  • rdful Mar 04, 2008
    are we talking about a control board sensor #34001495,and i have leveled so many times ( doesnt help ) i worn out my level
    thanks
    roger
    Genius:
  • 3,587 Answers
Ok..I'd suspect the mechanism for the timer is unhappy again.
and the shakes comes from imbalanced chassis. Try to re level it first..
Posted on Mar 04, 2008
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Error code od maytag Neptune
http://homeguides.sfgate.com/maytag-neptune-washer-model-mah8700-troubleshooting-codes-102595.html. Here's the site for Maytag Neptune Washers. You can also find other modes there. Hope this helps. Enjoy.
Sep 30, 2014 | Maytag MAH6500 Neptune Front Loading...
Maytag model mah8700 front load washer won't spin
Check the lid switch first, if that is not the problem, check timer control board and motor control unit.
Jul 20, 2010 | Maytag MAH8700A Front Load Washer
Front Load Maytag Neptune won't spin.
check the board
is the resister thats burning r-11
if it is you need to change the wax motor lock as well
its the door lock found where the door latch goes in
ive included the part number 22002119
they should have told you
Oct 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
I am doing a load of laundry the washing machine maytag neptune
This means locked rotor. you have a bad motor control unit. take the door off by removing the 4 screws also take the side/front panel off. You will see the motor control board. Do you have a delay wash cycle? If you do set it to delay wash remove the jp4 connector if the unit tumbles on it's own then the motor controller is fine but if it does not then you have a bad motor control board. Check it out and let me know. also there is a fuse on that board if you can locate it and check for continuity that will also help diagnose it. MAKE SURE YOU UNPLUG IT FIRST THOUGH!!!!
Jun 04, 2009 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH5500BWW Will not spin
maytag neptune washers do have a motor problem and they have a kit to replace the motor and motor controller.
when the motor fails, it wont wash or spin. most units have a 5 year parts warranty and should be replaced with a free part, but you will have to pay an authorized servicer to do this.
if it is over 5 years then i would call maytag and see if they will help you with an authorization for repair.
most of the time they will provide the part for free. just call the 800 # and ask for help. they wont send you the part but might give you some help with the parts.
Jan 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Can someone help me please,,,,, my maytag epic z front load washer..
I had gasoline spill on my purse and I put it in my front loader washer and now I have the worst smell of gas and it is awful and now I can't use my washer! Can anyone tell me how to get the smell out of my washer?
Jul 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Won't spin
you need to replace the wax motor door latch as i have read all of them have to be updated due to defect,if you need more info let me know-mike
Jun 09, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune washer
If the water is draining out o.k. then either there is no signal from the water level pressure switch, no signal from the control board or a problem with the Spin windings.
Mar 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH6700A Front Load Washer Logo
271 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
