Question about D-Link DP 301U (DP-301U) Print Server
Dp301p+ psadmin password was forgoten
I have print server but dont know the pasword of it i need to reset it please help meĀ
My friend gave me his dlink print server and the wrong password.
I called him about the right password, he told me "I Forgot What It Was"
HELP!!!
Reset The Printserver from Backside & Gave PAssword again
Posted on Jul 03, 2008
I want to reset the print server D-Link DP-301P+. I forgot IP address which I was changed according to network settings.
There are two steps that we can suggest,
A)
1) Install the psadmin software if you have not already. If you have lost the psadmin software then search for it on the web.
2) Start the psadmin software and click "factory reset".
3) If the software demands a password, try "SYSxxxx", where xxxx stands for the last four digits of the MAC address located on the underside of your server. (Example: if your MAC address were "63 XE 29 44 F2 96", then your password would be SYSF296.)
4) Click yes to confirm the reset.
B)
On the back of the print server you will find a pin hole, insert a paper clip for 30 secs with the print server powered on. All lights will flash. Try to setup the server again.
Hope this helps.
Regards,
Shrey
Jun 01, 2011 | D-Link DP 301P (DP-301P) Print Server
Hello, sorry i'am french so i don"t speak english very well i have a DP-301P+ print server and i would like to reset it can you help me to do this, the device don't have any reset button
I am looking for a solution as well. Some have said to login as psadmin and use SYSXXXX (XXXX being the last 4 of the mac address: ie. AA:3S:33 the password would be SYS3S33)
This did not work for me.
Even with the PSAdmin software, it requires a password to reset to defaults or to change the current password,
D-Link needed to put a reset button on this unit - this is stupid.
I will post if I find an answer.
Mar 07, 2011 | D-Link DP 301P (DP-301P) Print Server
I had forgot the printer server password. i had
Unfortunately, I don't know of a way to manually reset this without using the web-interface.
However, if it was somehow reset already, the default password for this unit is nothing. They do not use a password by default, so try it without one.
Ryan
Dec 02, 2009 | D-Link DP 301P (DP-301P) Print Server
I already change the ip address of my d-link dp-300u printserver and then i accidentally remove the check in the the tcip selection, when i reset again i can't see my printserver. how can i reset it to...
Reset button is in back panel of printer sertver.
Press it for 10 seconds.
Then all settings goes to defaults.
Reset button is small round in back side of router you can press it's pin with any ball -pen.
Let me know if you need further assistance.Thanks.
Nov 11, 2009 | D-Link DP 300U (DP-300U) Print Server
How can I reset my printer derver dp-300 to factory defualt values? Close
how reset password for dlink 300 print server please give me solution
Hi , please i have forgot my password Dlink dp 300u ,can you help me please?
Try using the psadmin software to do a factory reset. If it demands a password to do this, try using "SYSxxxx" (where xxxx stands for the last four digits of the MAC address written on the underside of the server. If you don't have the psadmin software you may be able to download it off the internet. After doing the reset you will need to follow the Quick Install Guide to set up the server. If you lost the Quick Install Guide you can download a new one from D-link's website. The following link may also be helpful: http://www.fixya.com/support/t224263-dp301p_psadmin_password_forgoten
Apr 20, 2009 | D-Link DP-300U (DHDP300U) Print Server
Forgotted the Ip of D-Link DP 300U print server
You may use the PSAdmin software to configure your print server even if you don't know the IP address. The only requirement is that the DP-300U has to be in the same network (subnet) as your PC running PSAdmin. In the PSAdmin, you will then be able to view or change the IP address.
Here is the link to download PSAdmin:
http://support.dlink.com/products/view.asp?productid=DP%2D300U#apps
Remember that if you also have forgotten the Admin password, you will have to ship the unit to D-Link in order to have it factory reset.
May 10, 2008 | D-Link DP 301P (DP-301P) Print Server
D-Link DP-300U
The DP-300U can be accessed with the password SYSxxxx, where "xxxx" is the last four digits of the unit's MAC address. The MAC address can be found printed on a sticker on the bottom of the unit.
Mar 04, 2008 | D-Link DP 301U (DP-301U) Print Server
Problems with your D-Link DP-300U LOST IP If you’re like me, you have a ton of computer **** laying around your house. Today I found an old D-Link DP-300U print server laying around and thought that I could put it to good use. The bad thing about these things is the fact that they do not have a hardware reset button on them, so if you forget the IP or the Password, you’re pretty much hosed… or so I thought. After doing some google searches for how to find a lost IP, I came back empty. The PS Admin program that D-Link publishes for use with this thing couldn’t find it on my network either. After some thinking, I came up with an idea.
If you know anything about networking and how networks work, you should have thought about this too. Get a Wireshark capture running. Unplug the power from the print server and then replug it. It’s going to send out an ARP on the network looking for it’s gateway which should be picked up by Wireshark. It should look like this:
capture.jpg In my case, it came back as 192.168.1.253. After changing the IP on my laptop to fit that subnet, I was able to log into it via it’s web interface (there was no password on it thank God!) and put it back to factory settings. Voila! What once was a brick is now a working print server!
I Copied it!
Shafiuddin Russel
infoshafi@gmail.com
+8801714073692
Feb 16, 2008 | D-Link DP-300U (DHDP300U) Print Server
Password was forgot psadmin of 301p
viaujocposted a brilliant solution which worked for my DP-300U: see http://www.fixya.com/support/t224263-dp301p_psadmin_password_forgoten
To paraphrase,
First try logging in with the following
username: psadmin
password: SYSXXXX
(where XXXX is the last four digits of the mac address)
If it works, you can proceed to reset the password.
Alternatively, you may be able to extract the original password from a configuration backup, if you have one. For details, see http://www.fixya.com/support/t224263-dp301p_psadmin_password_forgoten
Oct 17, 2007 | D-Link DP 301P (DP-301P) Print Server
D-Link DP 301U (DP-301U) Print Server Logo
2,110 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
