Question about Kyocera KM-1505 Copier
Add toner led is red
When i start a copy the copier sounds but not do the copy,
  • 682 Answers
To go to ready status toner level inside must be in optimum level-check toner bottlle many times and apply toner.
Posted on Mar 05, 2008
My newly installed Samsung CLP-310 has a red light showing next to the <...> icon. Please could you help me to resolve the problem. Thx
Hi paulette,
if the light is red and TONER COLORS LED all LEDs off
• The machine is experiencing an error, such as jammed paper, open cover, empty paper, installed waste toner container, or full waste toner container.
• The machine is experiencing a service required error, such as LSU error, fuser error, or Contact your sales or service representative.
if the light is red and TONER COLORS LED each LED lights red.
• Each toner cartridge is totally exhausted. You can not print.
• Each toner cartridge is wrong.
Aug 01, 2011 | Samsung CLP 300 Laser Printer
Canon 6035 keeps telling me to add toner when it is already full...error goes away after i open and close the hopper door..this seems to happen after every 5 or so copies(sorting and stapeling)
How do you know it's full? Did you record the copy count when you put the toner in? The only time the copier will indicate that it needs toner is when the developer unit is empty or if the toner sensor is not in contact with toner, you should hear a very high pitch squeal sound coming from the copier. If you are sure you have toner inside the developer unit then the toner sensor is bad. Does shaking the developer unit back and forth a few times help? Maybe the toner has developed a cave inside where the toner is supposewd to be touching the toner sensor.
Jun 23, 2011 | Canon NP 6035 Copier
When i turn on the copier it is stuck on 10 copies and a light flashes to the left of the copy number. I don't have a manual. I don't know what the flashing light means.
If the light is a red light with a flash shape then the machine probably has a jam. Look for jams and once you have cleared any jams switch the machine off and then on again. It could be the toner light if there are about six red dots - in this case you need to add toner.
Jun 30, 2009 | Canon NP 7130 Black and White Copier
Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
No error message but copier light doesn't come or number of copies doesn't work
let it run eventually the toner lite will come on, sharp copiers will run an extended period trying to add toner to the developer. developer is 70% iron filings and 30% toner as it uses the toner it cycles more in to stay at the proper level.
Apr 14, 2009 | Office Equipment & Supplies
Will not reset for next copy
Sounds as if it is low on toner.When they run low, the motor will continue to run trying to add more toner.The toner add system is a glorified flour sifter.Eventually it will set the add toner on.Good Luck
Mar 24, 2009 | Canon NP 7130 Black and White Copier
The start button won't turn green when power turned on.
if the machine needs toner you will be able to change paper size & reduction but the machine will not come to ready[green ready light lit]. so if the machine keeps running after you turn it on it needs toner. if you leave it on for lets say 15 min. does it give you an add toner light or an error code?
Dec 15, 2008 | Sharp AR-160 Copier
The start key does not stop its cycle
Control panel definitely needs replacement. Based on the age of the unit and the cost (at least $350) of the repair, I would recomend replacement.
Nov 10, 2008 | Canon NP 7130 Black and White Copier
Ricoh ft3713 toner overflow
remove the toner bottle, open the back cover and look for the small DIP Switch turn on and off, by doing this you are forcing the machine to come out from add toner condition. Then you do 20 sky shoot.
Oct 24, 2008 | Ricoh FT3713 Copier
Kyocera KM-1505 Copier Logo
114 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
