Question about Logitech Z-2300 Computer Speakers
Only getting half the volume
Recently moved w/ theZ-4 series, logitech 2.1 computer speakers w/ subwoofer. they worked fine w/ loud volume, but recently set up again after the new move and i'm only getting about 1/2 the volume when you turn the dial to full. why did i lose all that sound?.
Thanks, Mike
    Sergeant:
  • 300 Answers
The first things I would check would be the volume control within your operating system. If I assume you have Windows XP, you would go to Start-->All Program-->Accessories-->Entertainment and click "Volume Control". Make sure all of the sliders are at least 1/2 way up. You might also want to check to make sure the cable from the speakers to the computer is plugged into the proper jack (usually the green one), as sometimes computers have jacks for rear speakers, which might make them sound quieter.
Posted on Mar 04, 2008
Sub woofer got weak
If there is an adjustment, turn up the subwoofer volume. After you started shaking the house somebody may have adjusted it for you.
Check your computer control panels volume too, cause they may have a subwoofer volume there too.
If there is an equalizer (software) then make sure the low frequencies are set properly (middle or above). Check for this in your computer audio control panels.
If there is no adjustment anywhere, take it back, 'cause it is busted. If it is too late to take it back, sent it to logitech for repair under warranty. If it is too late for that, go buy a new one.
--Dave
Feb 07, 2010 | Logitech X-540 Computer Speakers
Logitech Z-5300 subwoofer from computer to i-pod problem...
The best thing to do is to contact the manufacturers. From this i understood that your speaker system is new. You surely have the manufacturer's guarantee. So its better to contact them than to get it repaired or replaced for free. Sir please do not try to open the sub as it will void the guarantee policy.
Hope your subs come into play as soon as possible.......
All the best...
Jan 05, 2010 | Logitech Z-5300e Surround Sound System...
Subwoofer sound only
Try agitating the controller (w/ the power button and volume control) and the speaker(s) that was out should immediately turned back on.
Aug 02, 2009 | Logitech X-240 Computer Speakers
Right speaker without controls has stopped working.
plese change the wires and try the permutation and combinations.this wil lead to find out if the fault is in wire or in the port. this is purely a hardware fault.
Jul 29, 2009 | Logitech X-230 Computer Speakers
Marantz 2220B with Sound Problem at Half volume
The most likely cause of this is some DC current working its way through the system. WIthout taking some measurements, it will be difficult to confirm this though. This should not be an expensive repair. Figure on $20 or so for parts (capacitors mostly).
Dan
Apr 12, 2009 | Marantz Audio Players & Recorders
Subwoofers not working on Logitech R-20 speakers; worked until recently
There must be a control on subwoofer, like a volume control. Turn it and check it. Also check the connections.
Jul 17, 2008 | Logitech R-20 Computer Speakers
Logitech X-540 5.1 speakers loudly crackle when volume moved up or down
mine does that, its complety ok. Just run them at highish volume for about 30 secs should fix them, its just static.
Feb 12, 2008 | Logitech Z-540 Speaker
Logitech Z-2300 speakers
maybe the first step could be checking the subwoofer's fuse.it is located over the power supply connector.
Jan 12, 2008 | Logitech Z-2300 Computer Speakers
Z5300e Subwoofer Problem.
in my view, it is due to any of the following
1. its fuse burnout or wire breaked, check fuse and cordwire
2. its subwoofer coil is damaged to loud volume, replace it
3. its amplifier IC is damaged, replace IC
Dec 31, 2007 | Logitech Z-5300 Computer Speakers
Logitech Z-2300 Computer Speakers Logo
121 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
