Sony Handycam DCR-DVD7 DVD Camcorder Logo
Posted on Mar 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sony dcr-dvd7 is not accept any disc his screen shown format error
Anonymous
Level 2:
New Friend:
  • Expert 108 Answers
  • Posted on Mar 03, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
108
Questions
0
Helped
26306
Points
337
Maybe your cam is has a problem with the lins just clean it a white soft cloth wipe just put small alcohol to make it wet the eye lins ant it will work again .
17helpful
2answers
SONY DCR-SR46 HNDYCAM, HDD FORMAT ERROR
my handycam sony dcr-sr46,i on the camera in screen hdd format error on screen what we do
2helpful
I get a message on the screen that says, "recording disabled." How do I fix this? I have a Sony Handycam DVD/RW Wide LCD
This message appears when mini dvd disc got some error in recording tracks, if its rewritable mini disc then format it as option is available in camera settings menu and if disc is once writable then use another disc as it can not be formatted.
Caution: Format will erase/ delete all files on dvd disc and refresh the dvd disc.
No camera image on screen while recording on sony DCR-DVD7 sound is recorded, playback from previous recordings are fine
If it is a white screen and you have been recording in bright daylight you may have the Night Plus slider on.
10helpful
2answers
12helpful
2answers
SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
C 13:02 dvd-rw mini disc errors
It's not recommended to format a disc in the Computer and use it in the Camcorder.
It seems that there is an issue with the disc.
The disc should be formatted within the Camcorder itself.
I will forward a link to a page where you can get the information regarding the error message appearing on the LCD screen of the Camcorder.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C79466
I have a HANDYCAM SONY DCR-DVD 106, and I keep getting the following message error - "Disc error. Unsupported format - 13:023, with regard to a mini MEMOREX DVD-R.
Disc error. Unsupported format means that ur camera does not support the format of this disc it might not support DVD-R or DVD-RW and supports the DVD+R and +RW try the other format disc and let me know if it resolved , check the manual it is stated on the box or manual which format it supports, if it does not solve ur problem try some other brand instead of MEMOREX try sony,hp,fuji,philips and see actually these sony cameras they are sometimes locked by the manufacturer to only use the original discs for monopoly sony acts like that in every product
pls do rate me if i fixya problem
regards
Zohail
Sony DCR DVD101 Format Error
I had the same problem, but I didn't have any valueable data on the DVD-RW (which was a Sony brand disc, go figure...). So, I backed up all the videos on the disc, tried to format the disc to get it ready to be able to be used again, and got the whole "Access Error" when I was formatting the disc. I tried both the VR and Video format options, the Video option came back with teh "Access Error" while the VR option came back with "Format Error". I put the disc into my DVD burner in my computer and was going to try and format it manually. But, as the disc popped up in My Computer and I right-clicked on the disc icon, there were no options to format the disc, which is unusual. I tried it in a laptop that's about a year old (versus the other computer which was about 4 years old), and as I right-clicked on the disc, an option was entitled "Erase this CD-RW". Obviously this was not a CD-RW, but I tried it anyways, and bam, after about half a minute, the mini DVD-RW was formatted! After that, I put it in the Handycam DCR DVD101 drive, formatted it using the Video setting (my preference), and now it works.
So, moral of the story is...try and format the disc manually on a DVD burning enabled computer. If it doesn't work, try a newer computer. But that's all I have, hope this helps!
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
