Question about 3Com 3C16985B /REF3COM SSII 24-PORT SWITCH (3C16985BREF)
Port in tunk
I put a door on trunk of a 3300xm sw with a gate of a cisco equipment?
  • forrito22c Mar 04, 2008
    It is possible to do this? Though different manufacturers.
    please i need your answer....
    Problem Solver:
  • 7 Answers
I'm not sure you can trunk vlans across diffarent manufacturers.
on the cisco you need to set trunk mode on blade/port and set type. if you can set same type on both switches then the trunk should come up
Posted on Mar 18, 2008
Cisco 3524 not receiving vlan info
Try this http://tools.cisco.com/search/results/display?url=http%3a%2f%2fwww.cisco.com%2fc%2fdam%2fen%2fus%2fproducts%2fcollateral%2fswitches%2fnexus-4000-series-switches%2f6701_catswitch_guide_v7_r5.pdf&pos=5&query=WS-C3524-XL-EN
Mar 08, 2014 | Cisco Catalyst® WS-C3524-XL-EN 24-Port...
I work at a school and we are trying to connect 2 HP 3com Baseline switch 3952 together. however when I plug in my Cisco SFP modules into both the switches, neither of the ports light up and establish a...
1.what type of fiber is:SM (single mode) or MM (multi mode)?
2.what type of sfp? 1550 or 1310 if is SM, how many conectors and what type of conectors
3.in 3com usualy u dont need to make a port anouncemant as u need in cisco so if the sfp are ok, i mean if they are pairs and the fiber is same type should work, second problem : sometime the cisco sfp(when is not original from cisco) got problem in other brands hapend to me whit zyxel sw,
so give me more data and i will help you
thanks
Sep 22, 2011 | 3Com Baseline Plus 2952 52 Port Gigabit...
I just replaced cisco 4506 with new 4506-e, the uplink port didn't work for trunking
Hi, if you installed a Supervisor 6L-E 10GE (X2) in the new 4506-E and you want to use the two 10GE uplinks as Gigabit, you need to type in the following config lines:
hw-module module 1 port-group 1 select gigabitethernet
hw-module module 1 port-group 2 select gigabitethernet
Jan 17, 2011 | Cisco Catalyst 4506-E Cat4500 E-series...
Hello, I have a Linksys SRW2016 and 2048 switches with one cisco 1800 series router. I have successfully created two vlans on one switch and when i try to connect a trunk port to cisco router it...
Make sure that the frame encapsulation is set on the router to 802.1q on each of the sub-interfaces. You could also try fixing the speed and duplex on both the router and the switch in case there is a problem negotiating the speed and duplex.
Hope that helps!
Oct 04, 2010 | Linksys SRW2016 (745883562435) 16x1000...
How can configure trunk
not sure about the 3COM side, but on the Cisco side... go to the configure prompt, then the port that you need to trunk (int [interface name and number] and enter)
Once you are in the interface, use the following command:
switchport trunk encap dot1q
switchport mode trunk
Then make sure that the interface is not shut down, connect the switches together and (hopefully) the 3COM will negotiate to trunking... if not you will need to manually configure the 3com.
Hope that this helps!
Jan 07, 2010 | 3Com Switch 4500 PWR 26-Port...
Lucent Cajun not talking to cisco catalyst
Not sure what Cat switches you have, but the cajun switch must use the same trunking encapsulation.  Older catalyst switches use ISL trunking which only work with Cisco switches.  Make the port between the lucent and cisco dot1q encapsulation on the cisco trunk port.  Also turn on debugging on the cisco and see what messages are generated.
Apr 27, 2009 | Lucent Cajun P220G Networking Switch
Cisco error on switch
%SYS-4-P2_WARN: 1/Tag 0 The switch generates %SYS-4-P2_WARN: 1/Tag 0… messages.
This example shows the syslog output that you see when this error occurs:
%SYS-4-P2_WARN: 1/Tag [dec] on packet from [ether] port [chars],
but port's native vlan is [dec] This message indicates that an 802.1Q-tagged packet was received on a nontrunk port. The VLAN that is derived from the packet tag is different from the port native VLAN. In the error message:
  • The Tag [dec] is the VLAN identifier from the packet.
  • The [ether] is the host MAC address.
  • The port [chars] is the port identifier.
  • The second [dec] is the native VLAN number.
There is a possibility that the local port is incorrectly configured as an access port instead of a trunk port. Alternately, the remote side can have been configured as a trunk port instead of an access port.
Verify that the local port is not incorrectly configured as an access port instead of a trunk port. Also, verify that the remote side is not configured as a trunk port instead of an access port.
Feb 06, 2008 | Cisco Catalyst 4006 Chassis ( 4006)
Cisco cva 122
PAT/NAT has to be configured to forward port 21 to your PC's IP address.
Have you had a look in the config/management page? If it supports this, it'll be there...
Feb 01, 2007 | Cisco CVA 122 (CVA122-SINGLE-1P) Modem
Computers & Internet Logo
169 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
john smith
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
