Question about Nikon Coolpix 5200 Digital Camera
Coolpix 5200 + 4GB SD card
Would a 4GB SD card work on the Coolpix 5200? I wonder what is the maximum capacity?
Actually, bigredguy is incorrect - at least in part.... All recent SD enabled devices will accept any SD card. However, there have been changes in the standard for SD cards and their devices to allow for the increase in storage size since the format was invented. See SD on Wikipedia for details - http://en.wikipedia.org/wiki/Secure_Digital_card Basically, check your device details before buying a larger card if it is more than a couple of years old.
Posted on Aug 03, 2008
I tried a 8gig from scandisk and does not work
Posted on Jul 03, 2008
  • 3 Answers
Any size SD card will work. The capacity limit is with the card, not the camera. All the camera does is serve as a recorder/reader for the card.
Posted on May 13, 2008
Everytime I turn it on its says out of memory or this card cant be used
That's a typical message on the L10 if you have either tried too large a capacity of SD card, or if you have used an SDHC car.
The L10 is compatible with SD cards ONLY up to an absolute maximum of 2GB capacity. It is incompatible with the commonly available SDHC cards which start at 4GB capacity.
If you are using the wrong type of card then your fix is to stick to using SD cards, and for the greatest reliability try to keep to a maximum of 1GB, as in common with many similarly specified models the L10 can be a bit fussy about brands when you push it to the 2GB limit.
I hope that my free and speedy answer has been of use, if so please take a moment to rate my reply. If not then instead of rating my answer, please add a comment giving details of exactly which card you have been using and whether you get the same problem with other SD cards and I'll try to provide further assistance.
Jun 21, 2011 | Nikon COOLPIX L10 Digital Camera
Why my 4GB SDcard can not work at my NIKON coolpix 5900
There are no 4GB SD cards. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Jan 16, 2011 | Nikon Coolpix 5900 Digital Camera
I have nikon coolpix s203. When i plug SD in unlocked position it shows "The card can not be used". When i plug SD card in locked position camera will see card but nothing writes io reads from...
You don't say whether this is a new card or one you used before. I'm going to assume this is a new card (otherwise, it means the card has become corrupted or there is a camera fault).
You say it is an SD card, but don't mention the capacity. "SD" cards larger than about 2GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
I expect your camera just won't work with this kind of card. It is often difficult to find out the maximum capacity memory card a camera will use, as today's cards are much larger that those available when the manual for the camera was written, but as a rule, if the memory size is larger than the largest size mentioned in the manual, you should expect trouble. You can always carry several smaller cards if you really need more space.
Dec 26, 2010 | Nikon Coolpix S203 Digital Camera
I Purchased a new SDHC card from Argos which was 4 GB as the one that came with my Nikon coolpix 3700 is a 16mb I put this new one into my camera and the camera showed that you couldn't use this card,...
Your camera will accept a maximum SD card capacity of 1GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 1GB capacity.
Please take a moment to rate my free answer.
Oct 06, 2010 | Nikon Coolpix 3700 Coolpix 4200 Coolpix...
Memory card won't format
You don't state which card you're having problems with, but a common cause is the use of a memory card which has too large a capacity for the camera.
Your camera accepts SD cards up to a maximum 2GB capacity. It will not cope with larger capacities and will produce error messages or fail to format the card. The most common cause of the problem is using the later specification SDHC cards in older devices which pre-date the use of SDHC cards.
If you are using the wrong capacity/type of card then you have just two fixes: either use an SD card with a maximum 2GB capacity or replace your camera for a later model which is SDHC compliant. Note that later devices can still use SD cards as well.
I hope you manage to use this information to solve your problem. If not, then please add a comment providing details and I will be happy to provide a relevant answer. If your problem has been solved already then please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Oct 03, 2010 | Nikon Coolpix 2200 Digital Camera
I have the JVC above and it requires an SD card. I inserted an SDHC card and it gave me an error. SD and SDHC are not the same? When I did try to but SD card only still on its label has SDHC. To be honest...
You are correct. SD and SDHC are not the same.
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
SDHC stands for Secure Digital High Capacity. It was a technical evolution which broke the 4GB maximum capacity of SD cards and allows up to 32GB. In turn they are eventually due to be superseded by SDXC cards (ecure Digital eXtended Capacity) which allow a maximum of 2TB.
May 30, 2010 | JVC Everio GZ-MG37 Camcorder
Nikon coolpix 3100 - maximum card support?
yes you would. It can inly accept 1GB cards. Just as a tip large capacity cards make it slow to recover from a write after taking a pic so if you can get say 512K cards still use those they recover from writing a lot faster
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Nikon COOLPIX Cameras
Nikon coolpix 2100- out of memory- After installing 4gb CF card
4GB requires FAT32. Camera firmware only supports FAT16. 4GB won't work because FAT16 has a 2GB maximum size limitation. 1GB CF card is Nikon's "approved" maximum for this camera.
Catch: 22 1GB -and lesser capacity- CF cards are no longer manufacturered or generally available in 2010. When the current CF card dies, the still working camera also becomes throwaway unless you can source a CF card 1GB or under. 2GB may work, but with 'issues' per caution below.
CAUTION: Anecdotal evidence suggests the final release -& current- firmware for cameras of this generation is also encumbered by with a maximum picture number limitation of 999, realistic at the time of original manufacture when 256MB was a the largest capacity CF card but completely nonsensical now.
Summary: This is my first NIkon Digital camera and also my last.
Apart from the noteriety of the ubiquitous broken Nikon plastic battery latch, a major design flaw Nikon refuse to acknowledge or accept liability to rectify -since self-repaired better than OEM, Nikon policy on firmware support is complete abandonment of product within an unacceptably short service window. ie: a deliberate poilicy of enforced obsolescence.
Suggested Problem Remedy: Do buy a new camera supporting SD Cards of current capacities. Don't buy anything branded Nikon.
May 24, 2009 | Nikon Coolpix 2100 Digital Camera
Memory Card Capacity for Nikon P4
you can put a 16 gig in without any trouble
Dec 20, 2008 | Nikon COOLPIX P4 Digital Camera
Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
May 17, 2008 | Pentax Optio S5n Digital Camera
Nikon Coolpix 5200 Digital Camera Logo
391 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
