Question about Sony KP-48S35 48" Rear Projection Television
TV is not coming on. tries but fails immediately
The two blinking lights in succession seem to spell a problem with the power transformer or AC ??? the code sheets online point to power supply ...any ideas if it is one or possibly more than one on the board?
  • big box Mar 04, 2008
    this is a KP-53HS10 model by the way. sorry
    I understand that Sony will take my G Board , refurbish it and send it back to me for $100.00 not bad. Thanks, I think that I solved it myself.
Called Sony, I'm sending them my G Board to get it refurbished for $100 - that should do it.
Posted on Mar 05, 2008
My tv flatscreen (LE40A557P2FXXU) seems to be stuck in stand by mode "red light flashing" and when switched on via remote nothing happens, ie tv wont come on. Also when the switch on the side of...
Internal checking circuits, most likely the high voltage circuit. Take off the rear cover. From where 120 volts AC, leads to a fuse, then to a small high voltage transformer, then a capacitor. Check DC voltage at the capacitor. For me it was 380 volts. This capacitor needed to be replaced. Samsung uses a 100 uf rated at 450 volts. Found some old power supplies and got two capacitors - 150 uf and 220 uf both rated at only 400 volts. Had to connect them in parallel making 370 uf. The voltage check was 391 volts, but my TV is now working.
Jan 08, 2018 | Samsung Televison & Video
Tv will not power up
These sets are bad about the flyback transformer and/or the horizontal output going bad. Have a repair shop check it out. This can be pricey depending on how much is bad.
Oct 13, 2009 | RCA F32450 32" TV
Battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
Jun 13, 2009 | Panasonic Toughbook 28 Notebook
Hi thanks for replying
The clicks you are referring to sound like High Voltage Leaks or Arcing. While it is clicking check for sparks around the high voltage transformer only with your eyes from a distance. If you see sparks shut it off immediately.
Dec 29, 2008 | Philips 42PFP5332D 42 in. Plasma...
Sharp R-1480 failed after a power outage
It's most likely the low voltage transformer that's part of the circuit board or a blown trace on the board. The HV transformer would only burn and smell if the unit was in a cook cycle.
The complete board assembly is only around $80. If you're really handy, you can order just the little transformer, but you'd have to remove (unsolder) the old one and install (resolder) the new one on. The circuit board is one assembly and it takes all of 30 minutes or less to replace from start to finish.
Check with Martin Microwave Inc. @ 1-877-894-0035 to order or to inquire.
Oct 30, 2008 | Sharp R-1480 Microwave Oven
TV stand by light blinks 10 times on powering ON
Replace Both of your STKs 392-110s up grade to 180s.
Aug 25, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV shuts itself off
Horizontal Out Transistor or Flyback Transformer seems bad. check n replace please.
Jun 08, 2008 | Sony KV-27S42 27" TV
Blank screen, no sound
If ti blinks three times, then it may be an issue with the flyback transformer. It's called "three strikes"...it tries three times to come on, and after that enters a safety shutdown mode to protect the TV. Might need to have a professional shop take a look at it.
May 02, 2007 | Durabrand DWT1905 TV
Red power light keeps blinking and wont come on
The first thing to try is to unplug the unit from the wall for about 15 minutes,if this does not work you will need the assistance of a servicer to diagnose the problem,if you are familiar with tv service you can check the horizontal output transistor for a short,sometimes it fails for no reason and other times it goes bad along with the horizontal output transformer also know as flyback.Be careful if you decide to check this yourself.
Oct 02, 2006 | Toshiba 50HX81 50" Rear Projection...
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
