Question about Car Audio & Video
Car amp fading hum
I bought my amp (Alpine MRP-F550) over a month ago, but finally got it installed only 2 weeks ago. At turn-on, I've noticed it has a LF hum (70hz?) that slowly damps out (10-40 secs). It happens whether I turn the key to start or accessory and is not dependent on volume. I also found that it doesn't happen every time I turn it on, only if it's been sitting off for a few minutes.
Has anyone experienced this or have any theories as to why it's happening?
-=Zzed=-
  • 1 more comment
  • Tygh Duval
    Tygh Duval Mar 10, 2008
    Although I did not personally install the amp, I know from talking to the installers that the preamp lines are run on the opposite side of the truck from the power wire.
    I also suspect the issue isn't the RCA jacks touching something metal, as I would expect the hum to be present constantly or at least intermittently. As it is, the amp only hums at turn-on and only after it's been off for at least a few minutes. It's never hummed while on nor immediately after being turned off.
    As for "making sure my frequencies aren't too high", I'm not sure what you are referring to. The amp is running door speakers that are almost full range (using the amp's built-in high-pass crossover at 60 Hz).
  • Tygh Duval
    Tygh Duval Mar 11, 2008
    If you'll read my initial description again, you'll notice that the problem:
    1. Fades after 10-20 seconds, so I can't tweak and adjust to my hearts content
    2. Still occurs even with no RCA preouts (aka the stereo) connected, so the volume of the stereo has no bearing on this issue.
    Plus, the gain is set to nominal, so I doubt that's the issue.
  • Tygh Duval
    Tygh Duval Mar 13, 2008
    I'll be the first one to admit I'm wrong, so here goes. When I mentioned that the gains were set to nominal, I hadn't actually checked them recently. When I went to tweak something on the amp today, I notice one gain (ch1&2 or 3&4, not sure which) was set slightly above nominal. A quick tweak back down, and it seems the hum has gone! So while I'm not sure why a gain adjustment fixes an issue that occurs even when the stereo is not connected, I'm glad its gone!
  • 24 Answers
Make sure your rca jacks arent touching any metal and your hot (+) cable is not ran on top of your rca jacks and check and make sure your frequencies arent too high
Posted on Mar 08, 2008
  • tony sanders Mar 11, 2008
    turn your gain level down and turn your radio up slowly add the gain level if it stops your amp is too high turn down enough till sound stops
I have a alpine MRP-M500 amp connected to 2 10 inch comp kicker subs. The problem is the subs rattle and distort. The subs have been tested ok and all the wiring has been tested also ok. What could be...
Any time that there is a rattling sound from the subs, that indicates that they are probably blown. How were the subs tested ok? If the resistance of the subs is still close to OK, that is good, but it doesn't necessarily indicate that they are working properly.
Try using different subs at a lower volume, or turning down the gain slightly.
Mar 11, 2011 | Alpine MRP-M500 Car Audio Amplifier
I have an alpine mrp-m2000 powering (4) alpine type r's. When I turn the volume up to about 2/3 of the way the amp starts to cut in and out. What could cause this? I was thinking it was just a tuning...
It sounds like the amp is at max power and is saving itself from frying.Different makers have different methods.If you want to you could call Alpine to verify it if you want but I bet they will say about the same thing.Good luck! Greg
Aug 16, 2010 | Alpine MRP-M2000 Car Amp
Car amp light turns on then slowly fades off?
makes sure all contacts are tru and no bad wires. tight fits and check all fuses
Mar 20, 2010 | Alpine MRP-M1000 Car Audio Amplifier
Equipment not turning on!???
Have you tried checking the remote wire yet? Because it could very possibly be that. Without a remote wire hooked up, you cannot get any power. Try that and see if it works.
Apr 29, 2009 | Alpine MRP-M500 Car Audio Amplifier
No light on Alpine MRP-M1000
Ok. Have you check the Ground and the Power connection.
Jan 25, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Alpine amplifiers fade in and out durring high volume bass hits
main problem i think you are having is your loosing power when it kicks a note.. get a power cap! power caps feed your amps constant power! this will solve your problem :)
Jan 06, 2009 | Alpine MRP-M450 Car Audio Amplifier
Problems with MRP-M650
as far as it staying on it may have been wired to your hot unstead of your remote on your radio
when it runs wide open it gets hot
how are your gains
I have an alpine and I just hooked up jl 12 w3s and it kinda j did what yours did
it played.. hit hard then no subs.. my mids and highs platyed, but until I would turn off the car and restart the radio the subs immediately came on and the subs are only connected to this aplpine mrp m 650 amp
what speakers and what ohm did they wire it too?
i think my problem was I was overloading my amp feeding it a 2 ohm load or a one ohm load and it was shutting down my subs.. protectection I suppose?
Jun 02, 2008 | Alpine MRP-M650 Car Audio Amplifier
Just died out..
Have you determined if the problem is with the amplifier or the subwoofer?
Have you checked the wiring to make sure that there are no loose connections?
Oct 18, 2007 | Alpine MRP-M450 Car Audio Amplifier
Alpine mrp-m450 Amp won't stay on
im having the same problem with my amp, I took it to best buy and they said the amp was recieving power and recieving signals from the deck and i had everything hooked up right but that in the circuit board all the connections were blown, meaning i have a blown amp, i hope this isnt your problem but it definetly sounds like it. GOODLUCK
Nov 12, 2006 | Alpine MRP-M450 Car Audio Amplifier
Blinking Led power light
I have a alpine MRP-M350 700 watts class D... i will ask if it can support 2 subwoofer a 1200 watts 10" JBL subwoofer?
Aug 22, 2006 | Alpine MRP-M350 Car Audio Amplifier
Car Audio & Video Logo
527 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
