Question about ASK Proxima L114 Projector Lamp for DP-5600, DP-5610, LC-7000U
Projector i bought a projector from a friend but the red warning light keeps flashing what causes this
  • 2,237 Answers
Lamp is over 2000 hours and needs replacing.
Posted on Aug 19, 2009
Why is my samsung printer saying prepare new image unit?
Imaging unit has a cerain page life and printer has finished those pages and is warning u to arrange for the same.
Aug 19, 2014 | SAMSUNG CLX-3185FW COL LASER MFC Projector...
Tip
Dp5600
i bought a projector from a friend but the red light keeps coming on what causes this
on Mar 04, 2008 | ASK Proxima L114 Projector Lamp for...
When amp turns red light keeps flashing
check the lamp ballast
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Jan 23, 2014 | ASK Proxima Office Equipment & Supplies
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
My data projector eiki LC-Xb23 goes off without warning and the warning light is flashing
If the power light & warning light both flash red, this indicates that the projector is overheating. Once the projector has cooled down the warning light would continue to flash red and the power light would be solid red.
You should clean the air filters.
The filters are located on the underside. Disconnect all cables and invert. remove the 2 air filters located at the front and rear by pullingthe latches. They are both rectangular in shape.
Being very careful not to damage them, you should rinse the dust out and leave them to dry fully before replacing them in the projector.
This should cure the problem.
Feb 17, 2011 | Eiki LC-XB23 XGA LCD Projector Multimedia...
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
No light. Bought a new bulb assembly and
There is a product leaflet for this model,
http://office.manualsonline.com/regman/exit/ct?url=aHR0cDovL21hcmtldGluZy5vcHRvbWF1c2EuY29tL1BERnMvYnJvY2h1cmVzL09wdG9tYV9UWDcwMF9Ccm9jaHVyZS5wZGY,&target=productDoc&idDeviceType=2726&idMfg=2278&idProduct=794832
to contact direct for help try Optoma Customer Service at 888-289-6786.
AndystUK
Nov 08, 2009 | Optoma TX700 Multimedia Projector
The lamp continues to flash red lights for power and lamp
I have the same problem as posted too, ordered 3 new lamps and they all still do the same thing. I`m starting to think its the projector that has a problem. Anyone got a solution other then keep buying new lamps and try getting it to work... I mean, after 3, how bad lucky can you be that they are all bad lamps...
Dec 04, 2008 | ViewSonic PJ500 Multimedia Projector
Warning lights
Just so you know guys (and this procedure is not for the faint hearted!). I had the slow one second red warning light flash. I checked the bulb, which was find and I left it powered off for 48 hours. My projector is no longer under warranty and would have cost me over £300 to have it looked at. I ventured inside to inspect the boards, once I removed the main board to check the power supply I heard movement from one of the light ducts. It took me a while to removed enough to discover the fixing screw which holds the imaging cube in place (which is between the 3 light ducts and the projector lens) had come out (!?) and was rolling around inside the unit. This would also explain why sometimes I could not focus my unit properly. I remounted the imaging cube, put the whole thing back together and PRESTO! My projector is working again.
lee.read@gamil.com
Jun 21, 2008 | Epson EMP 720 Multimedia Projector
Sanyo Pro xtra projector - warning light
We have a similar situation with our Sanyo Pro Xtrax. It will be on for about a hour and then the "warning temp" light would come flashing red, and the project would turn off on its own.
Feb 08, 2008 | Sanyo PLC XU33 Multimedia Projector
113 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
Steven Wander
Steven Wander
Delage guy
Delage guy
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
