Vizio 50 plazma,when i turn it on the screen is all crazy colors,and shuts right off after 2-3 seconds??? anyone have any ideas how to fix this...also if i hit the input button it shuts it off faster....
1. pull battery from remote for 10 seconds. This will force reboot of remote. test, if fail move ahead,
2. do a main reset on Tv,, pull power plug from power source,, wait 10 seconds, reconnect, turn on!, fail continue
3. ? when you turn on TV is the stand by led light amber, when you turn on LED\'s does it start to change color , but standby light is still on? if test positive with findings issue should be your motherboard or even power board but it should be Mo/Bo..
I have a 32inch vizio that kept going off. the company said remove it completly from all power,wait 30 seconds,push the on button for 15 seconds.plug back in and it should work.
Mine worked at first then it quit completly and the company did not return any of my e-mails. probably cause it is past the warrenty(they only warrent for 12 months)A friend of mine had the same problem, neither one of us will ever buy a vizio again and I tell everyone I know about this problem.
tv needs z sustain board to be replaced try www.vizioce.com or www.ebay.com the part # is on the board.
remove the back cover and is the board on your right side
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
hi have a samsung 50 inch plazma tv . But saddenly it turned out be green screen, i am realy mad becouse i bought it $3200 on july 2007. please give me any helppfull idea.
thanks biruk.
