Question about Mitsubishi WT-46809 46" Rear Projection Television
My Tv has red light (color) out of focus..I've tried tuning the lance but it's not the problem in the lance..it's something else..don't know what..do you?
  • 132 Answers
Your TV has three picture tubes which are aligned to properly converge the projected light beams on the screen. Each picture tube projects a single color of Blue Green or Red. During production your TV was carefully adjusted to properly align these colors. As a feature you have the ability to adjust these colors.thats called convergence.If you don't have a manual to show you how to adjust you can find one here http://www.mitsubishi-tv.com/support.html
Posted on Mar 03, 2010
SOURCE:
How do I fix my t.v color?
Are you talking about an old CRT TV?...if so its most likely lived beyond its age and time for a new TV
Dec 17, 2017 | LG Televison & Video
Red doesn't seem to be working properly, but doesn't appear to be a bad projector.
The red CRT tube is failing. They are rated at 3000 hrs of operation. Check the red CRT face to see if there is a lot of dirt on it or has a discoloration on the inside of the coolant chamber. These tubes are scarce and expensive. You may want to consider a new TV.
Apr 27, 2017 | Hitachi 46W500 46 in. TV/DVD Combo
Turned on tv and it looked like 3d. Found red horizontal convergence lines extremely bowed. Cannot correct with magic focus either in auto or manual. What is the fix and what is more cost effective ......
TAKE OFF THE FRONT PANEL AND FIND THE FOCAS ELECTRONIC FOCAS CONTROLS. USUALY BETWEEN THE LEFT SPEAKER AND THE FIRST CRT GUN. PAUSE A DVD WHEN THE CREDITS GOING. OR USE A MENU IN YOUR SAT RECEIVER TO LOOK AT. USEING THE GRID IN THE TV SOMTIMES IS NOT ACCURATE. YOU WILL SEE 6 SMALL KNOBS (RED,GREEN,BLUE)FOCUS AND(RED,GREEN,BLUE)SCREEN DRIVE .FOLLOW THESE STEPS 1 TURNDOWN RED AND BLUE SCREENDRIVE 2 FOCUS THE GREEN (YOU SHOULD SEE SCANLINES) 3 TURN DOWN THE GREEN SCREENDRIVE 4 TURN UP THE RED SD UNTILL YOU SEE RETRACE LINES THEN BACK IT OFF TILL THEY ARE GONE. 5 FOCUS RED (UNTILL YOU SEE SCANLINES) 6 TURN RED DOWN AND TURN UP BLUE 7 FOCUS BLUE (BLUE WILL NOT BE AS GOOD AS RED+GREEN NOW YOU ARE IN FOCUS, NOW YOU NEED TO GET SCREENDRIVE BACK THE BEST WAY IS TO, PAUSE A DVD ON A BLACK SCREEN SELECT PLAY MOVIE AND HIT PAUSE RIGHT AFTER . TURN ALL THE LIGHTS OFF IN THE ROOM AND USE A SMALL FLASHLIGHT TO ADJUST SCREENDRIVE SO YOU DONT MOVE FOCAS BY MISTAKE. THE TRICK IS TO END UP WITH A VERY FAINT GRAY SCREEN WITH EACH COLOR UP AS FAR AS YOU CAN WITHOUT SEEING ANY COLOR ON THE TV. WHEN YOU GET THIS TRY PLAYING THE MOVIE. MAKE SURE THE BRIGHTNESS AND CONTRAST IN THE TV ARE AT A NORMAL LEVEL BEFORE YOU START . COLOR,BRIGHTNESS,AND FOCUS IS NOW SET TO YOUR DVD PLAYER.DO A FINAL CONVERGANCE AND YOU ARE DONE!
IF YOU CAN'T GET A COLOR TO FOCUS YOU MAY HAVE TO DO THIS MANUALY. SOME TV'S YOU CAN LOOSEN THE NUT ON THE CRT LENS AND MANUALY FOCUS IT. (LIKE AN OLD CAMERA). IF YOU GET THIS FAR YOU MIGHT AS WELL CLEAN THE LENS WITH A VINEGER BASED GLASS CLEANER (SPRAY THE RAG NOT THE TV) TAKE A LOOK AT THE MIROR, CLEAN IF NEEDED. IF THE MIRROR IS REAL DIRTY THEN THE SCREEN MUST BE BAD TOO.TAKE THE SCREEN OFF AND CLEAN THE BACK SIDE IF NEEDED. LOOK INTO THE LENS AT THE PICTURE TUBE YOU SHOULD SEE A NICE BRIGHT CLEAN PICTURE IF IT LOOKS CLOUDY YOU NEED TO CHANGE THE LIQUID IN THE CRT GUNS.I DON,T THINK YOU WAN'T TO TRY THIS YOURSELF. TIP(I USE A LITTLE ARMOR ALL WHEN I CLEAN LENES, THIS REPELS DUST LIKE IN YOUR CAR) IF YOU CHANGE YOUR FLUID AND WANT TO KNOW WHERE TO GET NEW FLUID I PUT CLEAR ANTIFREEZE IN MY PIONEER TV 3YEARS AGO AND STILL LOOKS GREAT "NOT KIDING" HOPE ALL THIS YOU. IF YOU ARE NOT COMFORTABLE TO DO IT. HAVE IR SERVICE. REPAIRING THIS WILL BE YOUR BEST OPTION>THANKS
Jan 09, 2011 | Hitachi 51SWX20B 51" Rear Projection...
Sony rear projection tv kp-51ws500 no picture. Standby light blinking red 5 times. TV has sound but no picture. Before the picture went out TV was turning green then red and had curved lines going...
Blinking 5 times is a sign of at least one of the three video tubes overcurrenting, which will eventually shut off the image. It happened with me but with my red tube over-illuminating. The solution is to reduce the drive intensity on the offending tube. Remove the front speaker grill. Behind it you will find a panal with 6 pots, these are drive (brightness) and focus for each of the 3 colors. My fix was to turn down the red intensity to zero and (after a restart) bring it up slightly till the image was acceptable, colorwise. I did have to adjust all 3 intensities to get a decient color balance along with the focus's on all three tubes (the drive intensity adjustments will knock the focus out as you go). I used the auto-adjust patterns to focus on, and you may want to use a stationary image, such as a paused DVD scene or a video game, to focus on. I still haven't found a way to clear the error code, but I learned to ignore it. The result isn't perfect, but it's very acceptable and it'll do for awhile (and it didn't cost anything!). Good Luck.
Dec 11, 2010 | Sony KP-57WS500 57" Rear Projection...
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
I can't seem to get accurate color, and I've tried a bunch of different custom color and contrast options... what should I do? (There is a sort of sepia tint to the screen)
Try adjusting the Screen voltage. Easiest method I know of: remove rear cover, locate the FBT (has a large red wire running from it that attaches to the back of the tube). You will see 2 or 3 adjustment knobs on it the should be labeled if you look close (screen is normally on the bottom). Turn the TV to a black screen (often an empty input works well). Slowly adjust the screen voltage knob (small screwdriver required) Clockwise, until you see some beam trace lines on the screen. Now, begin slowly turning it Counter Clockwise until the lines are gone and the screen just turns black again. Press the menu button and use the on screen menu and the top knob(s) on the FBT to fine tune the focus. Leave the cover off for the moment and see if your color is better. Repeat the adjustment if needed. If this does not help your situation, you may have something else going on... let me know.
Mar 15, 2010 | Samsung Ultra SlimFit 20" Digital TV
57H81 Red Bleeds, Dull Color, Was Pink
change the l.c.d colour corretion board new £ 400 not worth doing in my opinion part hard to get i stopped reparing these 5 years ago . agro agro agro ebay part not good these sets have a horrible short life
Dec 08, 2008 | Toshiba 57H81 57" Rear Projection...
RCA P46921. Just changed flyback.
First, this assumes nothing else is going on to cause it. Here's what I did. Go to the 'green grid' via the v76 menu and go through the alignment there. Notice that there are red letters, blue letters, and a green grid. While you are in this screen, adjust the red, green, and blue focus watching the individual color's item until they are in focus. If they won't focus here, they won't focus and you have something else wrong (what I do not know). Then, return to normal programming, then select menu on the remote, then screen, then adjust projection tv convergence both horizontal and vertical crosshare. That ought to get it.
Mar 16, 2008 | RCA P46921 46" Rear Projection Television
JVC tv AV-27D304
Roger, if your contrast (sometimes called picture) and brightness controls are at max you can increase the tubes brightness by turning the "screen control" clockwise, be advised a little turn goes a long ways, don`t crank it too far or you will get retrace lines, you will have to remove the back from the set and follow the red wire down from the tube to the "flyback transformer" on the front of the flyback are 2 controls, focus and screen, do not move the focus control, this should fix your problem.
Nov 20, 2007 | JVC AV-48WP30 48" Rear Projection...
SONY 61" Rear Projection TV
you will need to get a service manual for the tv and enter the service mode. then you will need to readjust the convergence.
Oct 24, 2007 | Sony KP-53S65 53" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
284 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
