Question about Brother MFC 420CN All-In-One InkJet Printer
BROTHER PRINTER 420CN
It started telling me to change the cyan ink but it was over half full after trying to get it to take I went ahead and bought a new cyan ink and installed it. It still said the cyan needed changing. Now it is saying no cartridge and it won't let you do anything. I have tried turning it off, taking all of the cartridges out and installing them, making sure all of the lids click but nothing works. I have not had this printer but maybe a couple of years at best. Looking on-line I see it happens a fair amount with this printer but they never say how to fix it.
Send your response to pammiejean0629@aol.com, I don't use the alltel account.
Thanks
Pam Reichle
    Genius:
  • 3,587 Answers
Check the email I sent to you on this, PammieJean
and in meantime, here's where you'll find drivers update
Posted on Mar 04, 2008
Won't print cyan color
try reseating the magenta ink cartridge or replacing it.
Jan 21, 2013 | Brother MFC 420CN All-In-One InkJet...
I changed all my cartridges. Now it is telling me "ink empty yellow", and cyan. They are brand new.
go into the software you instal for your printer, choose clean ink, this my help.Then try to prin test page.
txexixs
Sep 11, 2010 | Brother MFC 420CN All-In-One InkJet...
Can you force a printer to print in grayscale?
Yes, you can bypass the color printing. The software you are using for printing can help you change from colour to gray scale or adjust it in the printer properties.
May 10, 2009 | Brother MFC 420CN All-In-One InkJet...
The black ink will not print on my Brother 420CN
Get a new printer. What probably happened, is that your printer went dry, meaning there was no ink left, and that wrecked the printing heads.
Jan 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-420CN Multifunction Printer Problem
power off, remove all carts, power on, reinsert carts, say yes to questions
fails then replace cyan or ink well is covered in ink
Jan 10, 2008 | Brother MFC 420CN All-In-One InkJet...
MFC-420cn printer says install cartridge. But there is a new one just installed.
by useing original brother carts instead of poor designed generic ones.
Or by answering the lcd-display question if you have changed the cart.
or by making sure that the plastic nose secures the cart which was placed well into the holder.
If that doesnt work, the circuit board might be defective.
Jan 09, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-420CN All-In-One
unplug maqchine from power. take all carts out. wait 5 minutes. connect machine to power. insert carts as demanded. give the right answer if machine asks if the carts are changed. machine will do some cleaning.
do you use generic ink? in that case you might have clogged the printhead with wrong ink. The ph cant be cleaned anymore.
nevertheless try this (carts should be nearly full!):
press menue then start mono (blue copy) then fourtimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4. Machine will display init_all. press start mono. machine will refill tubes and
ph with fresh ink and do some cleaning. after that press 7 then 6 then 3 and start mono. machine will do a powerpurge.
press zero then 9 to do a quality test print. If it cant do the job leave maintenance by pressing 9 then 9. do the test print manually by pressing ink etc.
If you still do not see any colors the ph is clogged and cant be fixed anymore. It has to be replaced.
Dec 03, 2007 | Brother MFC 420CN All-In-One InkJet...
Black Won't Print On MFC 420 CN
Use another new genuine (original brother) BK cart. Do the cleaning twice only for BK. Wait some time (4 hours). If the ink has dryed up, the cleaning ink will break up the dryed one. Do the cleaning again. If it doesnt work, please write again.
Sep 18, 2007 | Brother MFC 420CN All-In-One InkJet...
Mfc 420cn
Do use original brother ink to fix the problem: Do the cleaning twice (All colors and bk). You should see some blocks of the missing colors. If not printhead is damaged and cant be repaired (Dryed out or damaged valve or clogged with particles). If machine displays unable to clean, search googl for ERROR 46 (Reset and change of waist inktank)
Sep 03, 2007 | Brother MFC 420CN All-In-One InkJet...
No Magenta and No yellow
If you have really already run the cleaning cycle more than 20 times you should have get an error 46 which means that the printer cant clean anymore! So if not, use original brother inkcarts and do the the cleaning twice. If there is no block on the testsheet, the printhead is crashed. You cant fix it anymore.
Brother MFC 420CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
