Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
Dell 1800FP has slight yellow cast
I just purchased a Dell 1800FP off ebay, and when I tested it I felt it looked fine. Then, when I placed it next to my other 1800FP it was clear that the ebay one had a fairly pronounced yellow tint to it. Nothing in the monitor or computer settings is able to approach correcting it -- wondering if this is something that might be repairable or if it's not worth the cost/hassle and I should just learn to live with it? Thanks.
  • 55 Answers
Your Display cable (inside your monitor) needs to be replaced. (Or reseated)
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
Posted on Mar 14, 2008
DISPLAY HAS A YELLOW CAST
First test your monitor to another computer, if it works fine with another computer, then your video graphic card is damaged or the connection port, or cable is bad. and needs to be replaced. If the monitor do the same with the yellow cast with another computer, then your monitor may need to be adjust for coloring in the screen menu, or simply do a auto adjustment with the monitor option. If that donsn't solve the promblem then you need a new monitor.
Jan 30, 2011 | Dell Inspiron 580 Desktop Computer (Intel...
Led flashing no picture
disconnect the signal cable from the computer. if it shows color bars, it means your monitor is ok and your video card is faulty. if it still does the same thing. you need to reseat the video card if its not integrated.
hope this helps.
Apr 09, 2009 | Dell 1800FP Monitor
1800FP green LED is on, screen is black
power pack has issues could be a chip on the power pack or some capacitors on the power pack. the power pack supplies power to the inverter.
Feb 20, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Yellow printhead alignment
tyyrtytryer tr ty ryt try rty
Nov 17, 2008 | Dell 1320c Laser Printer
Ice 2as01 is broken again
Resolder diodes D903 and D906 in the secondary of power supply. The diodes are the two mounted to a heatsink. These are the reason the 2AS01 goes out in the first place. The solder joints on these two diodes breaks loose. If you don't solder them, the 2AS01 will go out again.
Aug 04, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1800FP
What's wrong with your monitor?
Feb 10, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP, green power light, black screen....
Its probably the inverter that lights up the screen that went bad.I have replaced inverter before with much sucess. If you feel comfortable opening the unit up I found one on ebay. Here is the link.
http://cgi.ebay.com/1800FP-LM181E06-FPD1830-18-LCD-Inverter-KUBNKM045A_W0QQitemZ300179625342QQihZ020QQcategoryZ74936QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Dec 09, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1800FP Dark, No Power but power supply seems fine. Help!
I just repaired 3 1800FP's - all dead, no lights.
Firstly a dead 2AS01 is 95% of the problem, because some fool designer left out the protective zener diode - cheapness.
Mouser Electronics does not have this part, but lists it at 37 cents in lots of 2500, and gettable at $2.66 somewhere else.
You must also replace the two small value electrolytics near this IC, as some had an ESR of 40 where <0.5 is where it should be.
I suppose as the electro's dry out, the spikes can zap the IC. The quacks on ebay flogging 2sa01's alone, probably hope to sell you another one down the track (at a fat markup).
There are 2 'Sam Young 2200uf' electros that really should be replaced, with ESR or 2-30 ! Ideally replace ALL electros, as the others will be off - but those 4 as a minimum and using a jewelers loupe, resolder other joints on the transformer and anything that looks more dull silverish, than the rest. A 1 inch used and worn paint scraper will get the case open easy.
DANGER, CAUTION : Finally when refitting the inverter board, ensure the steel tab is over the TOP middle of the board facing away from the power socket (SO YOU CAN SEE IT) . The board sides in flat. It is possible to scew the board down with a slight bend, with the tab pressing over the pcb tracks - very , very bad!
Now all I need is for some kind soul to improve the fix by stating what the value of the missing zener should be.
PS. Just because the caps are not bulging does not mean they should be OK. Most wrecked 10 year old power supplies have better ESR's, so the electronics must be hot under the cover.
I have seen bulging caps with a GOOD ESR, and non bulging ones with an ESR of 47.
Canberra
May 21, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
234 people viewed this question
Alun Cox
